heater broken - no hot air.
Hi,
my heater packed in - only blows cold air.
very annoying since my windows mist up all the time!
ford fiesta - 1996 1.8d mk4 endura de . without aircon.
wondering if anybody has any ideas as to what I need to check.
maybe related to some work I did on my car? - I have recently bled the radiator and put in new antifreeze mix . Also took off the air pipes when taking off the rocker cover.the two pipes that run into the center of the car under bonnet seem ok - one was hot and the other cold.
the heater motor seems ok because the air comes in fast but very cold!.
thanks in advance
Ian
thanks in advance
Ian
heater control valve common problem dont be surprised if you have to change it more than once either gets stuck on hot or cold its a pain in the arse,
At this time of the year, think I'd be tempted to route around it for now, so it just has hot water flow all the time, much better than cold.
I always hear of these valves going up the swanny, pity ford changed from the old air deflector design, did the job, and no water valve to bugger up.
cossie fan (unluckerly)
My sisters has the same fault if its the heater valve it will only blow hot! The two pin plug should have 12v on one pin and no more than 1v on the other when the dial is in the cold position then 12 on both when in the hot position also the resistance across the valve solenoid should be 5 - 25 ohms! when the ingnition is on u should feel the solenoid clicking if u unplug it and plug it back in u may find its a wireing fault between the control pannel and the valve as i put a valve on my sisters and it did fuck all!
My sisters only blue hot a few years ago and i changed it and it worked fine now it only blows cold chaged it and it did fuck all! may be the plunger inside can get stuck both ways? but i wouldent just wang one on lol id check the power to it at hot and cold first! as if thats wrong its not the valve and he will have wasted 30 quid and half an hour!
1 Post
Heater control valve, bet my car on it. Always the cause on Fiesta's and Puma's, they're shit! End of.
Normally situated in the centre of the scuttle panel. Looks like this...
![](https://img.auctiva.com/imgdata/7/3/2/4/6/7/webimg/278951419_o.jpg)
Sweet will u do the same bet over my sisters one one only blowing cold lol ive always fancyed a cossie focus
competant bodger
take the valve off and throw it in the bin, get two short lengths of copper pipe of the correct bore and put in place of the heater valve and enjoy both the hot air and the fact that you never have to replace it again
ajamesc i bet your sisters heater matrix is blocked
Think we have the same issue with our w reg 1.8td fiesta van (no heat) how can the pipes be swopped so it will run hot for now ? i take it this wont cause any problems ?
Cool thanks will give this a try
No my sisters has 0v on pin 2 of the plug to the heater valve when in the hot position so the soleniod is not moveing the small plunger across to let the hot water move round the system lol. And if u do as u say what u going to do in the summer when its hot out and your car is blowing hot air lol
07-10-2015 12:56 PM
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
