What size lines for wastegate and air injectors -3 or -4
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I have been looking and it doesn't seem like there are many places doing -3 to 7/16" for air injectors and -3 to 1/8th npt for wastegates but they are available everywhere for -4 so i assume that's the one to use,
Yea things are good, thanks. How you getting on with the fiesta?
We uesd a banjo fitting on the waste gate and had some fittings for the turbo and air injectors lying around. Not sure if there's any left but I'll have a look for you.
Fiesta is sitting up in primer now mate as haven't got the lump of cash to paint it at the moment so concentrating on building up engine and ancillaries, then once everything else is ready I will get it painted last I think.
I've sorted some aeroquip fittings now mate so not to worry, thanks anyway
Im after some too and was told -4.Where do the two pipes from the external waste gate go? Iv just fitted an external wastegate and air injectors to mine but dont know where the pipes go!
Generally if there are two ports on the wastegate you leave the top one open and use the one on side around the middle connected to the outlet of your air injector.
As always though, double check the installation instructions from the wastegate manufacturer.
Cool thanks,iv got 2 ports.I havnt got the instructions unfortunatly as i bought the set up second hand,but its a turbosmart wastegate.
