3 door brake prob
Old Jan 9, 2011 | 01:02 PM
Harris.'s Avatar
Harris.
Default 3 door brake prob
Not sure what to do next with the brakes on my 3 door , its had all new pads and discs and calipers all round and the rear ones feel like there stuck on when driving , would adjusting the handbrake cure this . Plus the little warning light on the dash (pic of disc and pad) has started flashing . Ive also fitted goodridge brake hoses on the back but left the ford front ones on for now, would this make a difference?
Old Jan 9, 2011 | 01:31 PM
Can you spin the back wheels when the car is jacked up?
Old Jan 9, 2011 | 06:32 PM
Harris.'s Avatar
Harris.
Just about mate
Old Jan 9, 2011 | 06:36 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Did you wind the rear caliper pistons back/in before fitting the rear pads?
Old Jan 9, 2011 | 06:39 PM
Harris.'s Avatar
Harris.
Yes mate i did that , i think ive just got shit calipers from ebay !!!
Old Jan 9, 2011 | 06:41 PM
Steve the Plumber
Without the pads in, if you pump the pedal, do the pistons move?
Dont pump too hard!
Old Jan 9, 2011 | 06:54 PM
Harris.'s Avatar
Harris.
I will have to remove the pads and take another look, cheers for your help mate
Old Jan 9, 2011 | 07:30 PM
If they are brand new pads some can be a bit "hairy", but should ease off within a few miles, I've found with some even with brand new calipers so not sticky with new discs and pads I couldn't turn the wheel, fortunately solved easy as I always take off the anti rattle shims off the rear of the pads!!
Old Jan 9, 2011 | 07:56 PM
Rax's Avatar
Rax
I cant quite remember when I did the rears on mine,but when you wound the pistons to the level you wanted was this with the handbrake loosened off or the cable disconnected ? Sure I did that,done the same as you,new discs pads and calipers and then adjust handbrake after.Try turning the wheel with the cable disconnected.
Old Jan 10, 2011 | 06:49 PM
Harris.'s Avatar
Harris.
I just undone the cable when i fitted mine
Old Jan 10, 2011 | 11:56 PM
Rax's Avatar
Rax
You maybe correct,I have a tendency too forget what I have done and I think my brain makes things up just to humour me
Did you not get a advice paper with the new calipers on fitting ?
My advice would be to slacken h/brake,disconnect off the caliper,wind the piston so you can spin the wheel freely but no massive gap from pad face to disc.Cable back on and adjust.If that dosnt work I have no idea
p.s I hope you get it sorted .
yatta
May 21, 2016 10:31 PM
gcfcos
88
Sep 15, 2015 03:48 PM
focus2351
Sep 9, 2015 09:33 PM
hopper350
Sep 4, 2015 12:53 AM
