flocking
Old Jan 8, 2011 | 10:11 AM
gus's Avatar
gus
Default flocking
can you flock mdf?
i wanna make a board to mount my socket set in the tool box and was gonna use mdf
but it would look gash left untouched so was wondering if flocking it would work / stick
Old Jan 8, 2011 | 05:52 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Hi Gus
Yes you can flock onto MDF no problem using an Aqueous Polyurethane.
It is important that the adhesive coating does not get absorbed by the surface of the substrate, therefore, because wood is a porous material, a primer such as PVA or Acrylic Primer may have to be used prior to the adhesive being applied.
Hope this helps
Chris
Old Jan 8, 2011 | 05:57 PM
v man's Avatar
v man
Zee Germans are coming
you can as said but if it gets rubbed hard by anything it will mark it and look shit after a while anyway
just get some speaker carpet and cover it in that
at least you can hover it
Old Jan 12, 2011 | 09:38 PM
1223456's Avatar
1223456
MDF is perfectly fine to flock as we have done many ice builds made from this, as Chris said you must seal the surface first, we use the process of laminating which is exactly the same as we do for roof linings and doors cards which are made from a cardboard material.
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
FlashRS
Sep 14, 2015 12:36 PM
RSmark84
20
Aug 24, 2015 02:17 AM
