General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I cant see it making any difference done it on other cars, no air will be going though it in the summer any way, you just need to join the 2 pipes together
Not a good idea IMO to bypass the heater matrix I done it on my old 4x4 saff and it always ran very hot.
Bypassing the heater matrix will make no difference as long as the pipes are simply joined unless you had an existing cooling problem and you were using the heater to pull the temps down?
Anyhow, the pipe required is available from Roose.
at the moment i got it running from the modine to the back water outlet with the sensor,and the other from the modine round the back of the engine to the water pump but ive got a few joins there instead of just 2 joins
I would just join the 2 pipes together, don't know why anyone would not want a heater.
It is perfectly safe to block the holes as roosie has done.
if i just put the 2 pipes together i wont have it running through the modine will i?
