Question on turbocharging a pinto engine ????
Wanting A Cossie Rep
my mate has a sierra 3dr cosworth rep with a 2.0 pinto engine in it and he wants to turbo it but what would you need to do to turbo a pinto and what hp gain would you get from it
probebly be better dropping a 24v'er init be far cheaper and around the same sort of bhp if not more
he would need
turbo
manifold
exhaust sorting to mate to the turbo
sort the sump for the turbo oil return
better breather setup
and not sure but would probebly need to sort the fueling i.e aftermarket ecu or chip etc etc
like i say probly better dropping a 24v'er
he would need
turbo
manifold
Depends on how much power he wants, can be done on carb a lot easier than efi, if only low boost cr will be ok, either way though a lot of work for not much gain at std comp/low boost.
He'd be better off with 48's etc or dropping a vaux XE in there, way better than the 24v ford stuff.
i had exactly the same thing in mk midnight blue rs2000 mk2, its a full on conversion using the 2 litre sierra fuel injection system and i believe it was l1 cossie management but not 100% sure on that, no need to change pistons as they are low pressure turbo at only 7 psi, mine was quick enough to stay wiyh a stage 1 esc cos so not sure of the power but i think it was about 170bhp
2-210bhp for cheap money buy a whole granny for 300 quid and loads of torque
his engine has carbs on it he also just wants to have a turbo sound so i think he would just want low boost but is it a hard job to do as it sounds like he needs alot of stuff to buy
is his current pino carb'd or injected?
if its injected then its realy quite easy, easy enough on carb as well i supppose,
hardest part is prob finding the parts to convert it
you posted while i was writing
if its on 48's then its actualy a bit more comlicated, (not rocket science)
you'd need to seal the carbs in a inlet chamber to force the air out the turbo into,
take a bit of fabrication but again it is doable but cost a couple quid just to get a noise
i turbo my pinto 1600cc run it at 12 psi at the end on high comp
mapped my self made 107 bhp at 6 psi not sure how much when
turned up but could burn off most st 150 fiesta in my cortina
iam doing a new build with a 2000cc and a hx35 t5 box as my old one let go [gearbox]
http://www.rovertech.net/forum/viewt...?f=38&t=122699
Zee Germans are coming
If u can find one a 2.3 "Lima" pinto Turbo as found in lateish mustangs bit crap as standard with all the Yank emissions stuff on it but supposed to go quite well once sorted.
big_Rad
15-09-2017 09:36 AM
