Most responsive small turbo on standard internal Cosworth ?
#42
#43
Has development of the VATN / variable nozzle turbochargers for petrol engines been given up by manufacturers ?
Biggest reason I sold my Sapphire was the awful low speed torque, it would be nice if a turbo could make good boost low down and still pull at high revs!
Edit to add dyno graph
Is this unusually crap ▲ ?
Turbo was a T3 with bigger compresor wheel, car had a big Pace intercooler, light green injectors magnex exhaust along with an unkown chip.
Mark
Mark
#44
that wont happen,i have a lot of experience of the hx35 (specifically the 7 blade 12cm rear housing variety) on 2 litre 16v turbos and you will NEVER be spooling that in the range you are looking for,it will push 600bhp if required,its not going to spool like a .48 t3! id say full boost 4-4.5k rpm on one of those from experience.
#45
Mark
Mark
Really with a modern unit, there is little reason a sub 300bhp car cant be making full boost by 3000rpm.
You certainly wont find many original Jap engines/turbos pushing 280-300bhp hanging around until 4000rpm before they go.
Engines may play a part...but not that much.
#46
Testing the future
#51
Testing the future
#54
Thanks for the info guys.
Before I change turbos I have decided to get it remapped to see what improvment can be made on the current set-up.
In addition to the .48 housing in the garage, Ive also got a 4wd exhaust manifold that could replace the current 2wd manifold thats on the car at present.
#57
