Act gauges
#1 in Spelling Club
Has it got the Probe in a Plastic Elbow?? If so, they normally go into the Top on the Inlet Manifold in the right hand port (viewed from the front of the car).
If its just a sensor 'bulb' on the end of a wire, then its best to go under the hose that connects the Inlet Crossover pipe to the Throttle Body. The sensor must dangle in the airflow away from the walls of the Intake, but you must make sure it can't hit the throttle butterfly under extreme airflow.
Hope this helps.
Hope this helps.
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
