standard springs for 4x4 sapp..
Dose anyone know where I can get standard ride height 4x4 sapp springs from? I have new'ish lowered 40mm ones on are they worth anything?
Swap or deal?
cheers
steve
Swap or deal?
cheers
steve
OCD Victim
You can try AVO from Chassis Dynamics as they do uprated poundage, but normal height springs, or you can get genuine ones from Ford. They are around £80 plus postage, but you can get discount off that if you ask them nicely. Bayjoo ones are also available I believe. The AVO ones though are better than the Ford ones. I had new genuine Ford ones on my 4be and I took them off and fitted the AVO ones which dropped the front 2mm and the rear 29mm. The ride is softer than the OE, yet better and I still have not problems with speed humps, etc... I cannot comment on the other brands as I do not normally use them.
As for genuine Ford ones, the rears are a pair, the fronts are individual left and right due to weight differences. I can dig out the part numbers if you require them?
What he ^^ said, the Bayjoo (Leda) ones do lower the car though so I believe although nothing major, around 10MM IIRC.
Diden't know the 4x4 ones are available from Ford, I tried a little while ago getting standard springs but they don't do them for the 2WD![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
Martin
Martin
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
