cossie 4x4 oil pump priming best option?
going to be fitting the sump to my engine this week and I want to know the best way to prime the new oil pump, the engine wont be fitted and running for a couple of months.
I have so far been recomended to fill it with vasiline or light grease (which I have some on the shelf) or just use oil.
any one got any ideas?
steve
steve
Use some heavy weight oil like a 20W just to fill the pump, vaseline can be used but doesn't disolve that fast when cold in the oil.
If only a few months just wet the internals of the pump with 20 weight oil and put together, spin over with plugs out when starting to get pressure up, will be fine with that.
1st to 200 without NOS
Dizzy out, 6mm 1/4 drive socket on an extention and spin up with a drill clockwise.
Location: Yarm (Teesside) previously from Fyvie (Aberdeenshire)
You could do it that way but doing it with the dizzy out means you cand also turn the engine over.
Also when it comes to starting make sure you have got oil at the turbo before you fire it up.
big_Rad
15-09-2017 09:36 AM
mrmann
20-08-2015 11:24 PM
