VAG people AGU/BAM etc
#41
Boost addict
sorry to go off topic chip
martin do you still have the 20vt rover ? i cant believe that some of the zr owners aint doing that conversion instead of the t series turbo. iv noticed a couple of guys that have 20vt converted r5 gt turbos and tbh if i was going for 250-300bhp this is the way id like to go.
anyway back onto topic id defo look at the k04 turbo if your looking for 280-300bhp maybe can yield a bit more with the jabba manifold etc
#42
Plus I would quite like to use the ECU for a screen used as a dashboard which I can do readily with an aftermarket ECU, and not with the OE one.
#43
1st to 200 without NOS
#45
Martin, I assume you are on the rover gearbox are you?
If so, whats involved in fitting it to that engine, as its got a LSD so potentially a good box for me to use seeing as I have to have shafts made anyway?
#46
Theres plenty available for the ME7.5.
Theres even tuners doing software that allows you to tweak and modify their maps yourself. (Eurodyne Maestro 7 is one that springs to mind)
Some tuners are also doing "MAFLess" tunes, which while i dont understand fully, seem to use the wideband lambda as the primary source of fuelling info?
#48
Kevin, But what advantage do any of these standard ecu based setups off me over an aftermarket ecu I already have so costs me nothing but a few quid to make a loom and will map myself for free anyway?
#50
Martin, that box fits up there nicely, I assume the equal length shaft bit is standard rover?
I know you arent a trader, so I will go and look on your website to see if I can find a price for the conversion parts to fit the vag engine upto the rover box, and i'll update the thread if I can find that info.
#51
VW 20v engine to Rover PG1 gearbox adaptor plate
Billet aluminium adaptor plate that allows the Rover PG1 gearbox to be bolted straight onto the Audi/VW/Seat 20V turbo engine. This plate makes the fitment of the VAG engine into Rover/Lotus much simpler. You would also need a custom flywheel available at Ł225 plus VAT.
Price = Ł275.00 (excl. V.A.T.)
Price = Ł323.13 (incl. V.A.T. @ 17.5%)
Click HERE for more information and photo'
How much do the LSD boxes tend to go for martin?
They are quite a light box IIRC?
Gets me the two things I want most out of a box, the LSD and the Equal length shaft all in one fail swoop, and the change on the VAG boxes isnt great and from what I remember of those boxes they change quite nicely?
Whats your honest opinion of the PG1 box overall as one for a conversion like this Martin?
Cable clutch and rod change I take it?
#52
500 + a donation to the VATman sounds pretty reasonable in the grand scheme of things.
Clutch actuation is by cable or hydraulic depending on the model the box comes out of but all the bits are interchangable.
There are basically 2 types of PG1 box... the std one that's fitted to the lesser powered cars 1.8 4 pots and the 'uprate' box which is fitted to turbo and V6 models... That's the one to go for.
Btw, turbo shown in those pics is a K04
#54
Cable clutch would suit me TBH as that is what the pedal box in my car is for, but its nice to have the option to upgrade to hydraulic later on.
Sounds like the ideal box, and it looks like it will fit the space better than a VAG one will!
Whats the change like? I assume you are happy with it on Morris?
Actually, just realised the elises I have driven had those boxes didnt they? If so, it was a great change compared to most standard boxes
#55
I started with a ZS180 V6 box as I had a new one sitting there (they have no lsd as std) , added a Quaife ATB , swapped the belhousing for a 4 pot one (straight bolt on), changed the final drive from 3.9 to 4.2 and fitted steel caged bearings and it hasn't missed a beat yet ... Which is amazing as about 5 people shared the car at Bedford last time out.
#56
Well porkie is a hard man to impress with such things, so if its good for him its good for me.
Sounds like a good solid set of modifications to do to the box, have been having a read around and seen people doing similar with the elise's
Have certainly seen your car taking a beating and if Lee "I have utterly no mechanical sympathy" Manning couldnt break it then thats a good sign too.
Is that equal length shaft in your pictures a standard rover item?
#57
I ve linked a spreadsheet that clubgti put together for the 1.8t engine variations,
Also it would be worth looking on Seatcupra.net as the have an excellent technical section I would definitely recommend looking at Badger5 sections on their
http://www.clubgti.com/downloads/1.8...des%20list.xls
#64
VVT on 20v's is for emissions use.... there is no performance advantage in having it as std (AFAIK) but..... it has been used on custom maps to improve spool time on larger turbo's (as seen on the monster 750 odd bhp lime green Mk2 Golf) and Custom Code do a 'VVT Attack' version of their software but I haven't seen any results of what effect that has as yet...
Sorry Chip Martin beat me to it
Here is JBS (Custom Code)s new VVT Attack map http://www.jbsautodesigns.co.uk/prod...vvt-attack-18t
#65
Thats interesting, will have to find out if they fit, although TBH im quite sold on this rover box idea now, especially if its lighter like I suspect it is as weight that far forwards really does bother me (weight in the drivers seat im fine with though before some funny cunt says it )
#66
Interesting reading none the less though.
#67
36kg for a PG1 box without oil in it apparently.
Anyone happen to know a reliable source for the weight of the vag boxes?
Engine weight for one of the AGU/BAM etc engines would be good too, including all ancilleries preferably if anyone can help?
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
