How do you??
Old Dec 12, 2010 | 10:21 AM
charlie luciano's Avatar
charlie luciano
Default How do you??
Change the bulbs in the rear lights of a ford focus mk1??
Help much appreciated
Luciano
Old Dec 12, 2010 | 10:32 AM
Escow-Van's Avatar
Escow-Van
Quick look in haynes, says you have to take the cluster off. Looks like standard twisty connectors in there then.
Only looks like a few screws.
Old Dec 12, 2010 | 10:35 AM
rapid3door's Avatar
rapid3door
hi mate you have to take the rear light out
Old Dec 12, 2010 | 11:04 AM
steves24V's's Avatar
steves24V's
1 or 2 screw's down the side of the light between the light and boot seal (with the boot open) then a wing nut type thing in the back of the light just under the side shelf that the parcel shelf sits on maybe behind a flap of carpet.
Old Dec 12, 2010 | 11:12 AM
dojj's Avatar
dojj
Resident Wrestling Legend
from what i can remember, there are only 2 plastic screw things that hold the lamps in place
but some clusters have a little clipped in thing that you can remove with the bulbs in like the sierras do, but i think it's the whole thing you need to get out to change it
Old Dec 12, 2010 | 11:13 AM
phil_focus's Avatar
phil_focus
easy, remove the cluster.
theres a plastic nut in the boot you undo by hand and a screw on the outside, then give it a wiggle
Old Dec 12, 2010 | 11:16 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
As above Charlie - easy to do, 5 minute job.
Old Dec 12, 2010 | 12:16 PM
charlie luciano
Many thanks all just back from tesco's I'll have a go at it after a cuppa
Luciano
