cosworth power steering ??
Old 29-01-2005, 06:42 PM
tosh
tosh's Avatar
Default cosworth power steering ??
Hi
Going to flush out my power stearing fluid for the 2nd time,
The fluid keep's going milky since i put a 4x4 bonnet on the sapph/coz
( I think it's because the louvre allows water to get into the reservour via the little slot by the breather nipple on the 2wd cap )
So I'm putting a new 4x4 bottle & cap on, because the cap was different to the 2wd, ( ie there is no slot & it's a screw on lid )
I'm probably talking crap but there must have been a reason that the 4x4 sapph hade a different cap & bottle.
O'yeah back to the Question?
Does any one now which hose on the tank is the flow & which is the return? because I'm going to take off the reservour & connect 5 ltr's of cheap fluid to the flow pipe & crank the engine over (in short birsts) with the coil negative lead disconnected, letting the waste fluid from the return pipe go into a container, and hope this will get rid of any moisture left in the system.
If any one has experienced the same problem, and think this will work please let me know.
I know this is all a bit long winded but literacy & letters are not my strong point.
(QUOTE)
Cant read or write in the day because i only went to night school
Old 29-01-2005, 07:16 PM
D7AKE
D7AKE's Avatar
Just read you post and I have had the exact same problem....... and did this fix this morning!!!
I have a 4wd vented bonnet but I broke the cap on mine and water sat in the top of the cap and got inside I have just swapped mine 4 a 4wd item... with a screw top
The best way to drain is to release the main hose the one to the front let it drain and then turn the steering from lock to lock a couple of times most will come out.
The return pipe is the smaller pipe behind
btw the fluid in mine was like a strawberry milkshake from maccy d's
Hope this helps
Si
Old 29-01-2005, 08:41 PM
tosh
tosh's Avatar
Thanks for the quick reply.
I have been told that you need to flush out the complete system to totally get rid of all the contaminated fluid & moisture, that's why I was going to do it from the hoses at the reservoir end.
I was not sure which hose at that end was the flow hose (correct me if I'm wrong I think it's the larger diameter pipe, "the curley one").
Jay,
24-08-2015 05:26 PM
IAN RS2k
18-08-2015 07:51 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
14-08-2015 07:29 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: cosworth power steering ??
