ecu boost control
hi,
i run omex 600 and am having a turbo 1600 zetec se engine built at the moment, how and what fo i need for the ecu to regulate the boost and is that the best way of doing it? or if not what is? i would like it to be adjustable even if it is just a low and high setting
thanks
thanks
doess the 600 defo have boost control as I tho0ught it was the 700+ series which had this option. Sorry if this is miss info, if so an amal valve should work or as above a boost solenoid off ebay etc
im not sure omex 600 can control boost via ecu my mate was told to use an apexi another profec.... i thought only the 710 had feature to control boost???
you will need a boost control solenoid
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
