Fuel Set Up
Fuel Set Up
I need to sort out a fuel set up for my Mk2 fiesta, which is running a zetec turbo engine
I wont a fuel cell, and i know i need a 044 fuel pump but what else will i need? swirl pot? lift pump?
Also what size fuel pipe do i need? also i wont to use aeroquip unions etc but what size - do i need as i have a friend going to the states and can pick them up for me while there over there
Cheer's Brian
Cheer's Brian
What you need depends on what tank you run.
If you have to lift the fuel out the top of the tank for track work you will benefit from running a swirl pot to reduce fuel starvation due to surge, but that means more fuel pumps and fittings.
However if running a sumped tank you will only need one pump and the correct filters.
kosienutter
31
22-08-2015 09:55 AM
