Enhanced Performance Tomorrow
Old 13-12-2010, 04:28 PM
  #81
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Originally Posted by Rob_DOHC
I wouldn't, if the bearings show very little to no wear all is good in the world of the bottom end, you introduce more scope for fuck up by changing bearings.
Rob,
Agreed. When I was building an ST170 engine in the summer I measured all the clearances and found one brand new big end shell to be out of tolerance. I put some used but in very good condition shells in to measure and found one of them to be perfect tolerance. Built the engine with that and it's been happily abused to 8000rpm every day for the last 10,000 miles or so faultlessly
Old 13-12-2010, 05:18 PM
  #82
tiny2white
tiny2white's Avatar
Rob,
my thoughts exact
Old 13-12-2010, 08:06 PM
  #83
Danny @ Enhanced Performance
Danny @ Enhanced Performance's Avatar
I was there ealrier when it came apart and the oil pump has some scores but the lid if fine .
There was shit stuck to the strainer and something magnetic in the sump(cant work out what yet)the shells arent bad at all and everything else looks good..
Turbo re build,new oil pump,new oil feed pipe to turbo and jack shaft out as i think the bit weve found has something to do with that and id now advise on new bigs and mains..
cheers danny
Old 13-12-2010, 08:15 PM
  #84
Fudgey
Baby Cheesus
Fudgey's Avatar
cheers rob.
how do you tell then if its a dirty build?
as my block was machined, and so was the head....
but it all looked clean when i got it back and built it up....
its done almost 50 miles now, plus been ran in and mapped on the rollers, so would i have seen a failure by now if it was dirty?
turbo feed is also from the block.
Old 13-12-2010, 08:44 PM
  #85
Rob_DOHC
Rob_DOHC's Avatar
No worries mate,
My engine was scrubbed and jet washed for 2 hours, i then put the air line up all of the galleries and STILL got some shit out. A main bearing clearance is say 0.02mm, to put it into perspective a grain of sand is between 0.063 mm to 0.2mm so you wouldn't necessarily see dirt from machining especially if its in a gallery.
If something is bigger than the bearing clearance and is made of a harder material than the shells and or journal, the shells or journal WILL be damaged.
A scratch in a shell isn't terminal.
Personally i would never run an engine in on a dyno, personal opinion. And if you didn't scrub your engine and galleries after machining was done i would definitely be changing my oil about now mate, just as a precaution.
If it was a very dirty build it would have failed by now buddy so i wouldn't worry too much, if it wasn't too bad it will just shorten the life of an engine, give lower oil pressure etc.
Have a read of this, Federal-Mogul own AE etc, and have some very good articles about bearing failure, i've got a PDF somewhere which is very very informative.... but fucking boring lol, the below link sums it up pretty well,
http://www.activeboard.com/forum.spa...picID=33338167
Shows dirt as being the main reason for bearing failure/short life, 45% of all failure is because of dirt.
Rob,
Old 13-12-2010, 08:50 PM
  #86
Big Will_
Big Will_'s Avatar
When i'm building engines I stand with my machinist while all the parts are hot washed and bagged before I leave with them, once i get them back they all get pressure washed with a steam cleaner, WD40'd and airlined.
After a mock build I squirt brake cleaner down all the oil galleries and airline it out onto white tissue and I keep going until it's 100% clean.
It's frightening how easily something get stuck inside and engine and when it comes loose, it causes havoc!
Old 13-12-2010, 08:52 PM
  #87
Fudgey
Baby Cheesus
Fudgey's Avatar
they should have changed the oil before mapping it, after running it for a short period at my request. i will phone and ask tomoz.
if not, i think ill be buying some oil
Old 13-12-2010, 08:55 PM
  #88
Rob_DOHC
Rob_DOHC's Avatar
Can never change oil enough mate,
Rob,
Old 13-12-2010, 09:26 PM
  #89
tiny2white
tiny2white's Avatar
No worries mate,
Rob,
just read this link. the one thing that interested me was the note on oil dilution how much problems could this cause and could this account for the alloy fileings in the filter???
edited to add:
just wondering if the oil was diluted would pressure be lost towards the top of the engine causing wear on the head explaining the alloy as the head is the main source of alloy?
Old 13-12-2010, 09:34 PM
  #90
Rob_DOHC
Rob_DOHC's Avatar
Problem is mate, you have to work out where 'alloy' filings could actually come from. The block is iron, the crank shaft and cams are cast steel.
Leaving the head and oil pump as far as i know..... shells are probably lead copper etcetc, you would be in serious trouble if it was pistons leaving filing, and i don't know what material turbo bearings are???? as the turbo failed it may well have shit filings into the sump then back into the turbo filter????
If it were me i would do as Danny has said, change the oil pump as pressure is low, change the oil and carefully fit new bearings if they are worn, as said i don't agree with running engines in on Dynos but that is a personal opinion, and if it were me and i thought i needed to fit new bearings i would have the engine out to do it properly. Lets hope you don't mate.
Fuel contamination of oil leaves the oil smelling of petrol.
Sorry buddy, its a shit thing to happen
Rob,
Old 13-12-2010, 09:38 PM
  #91
tiny2white
tiny2white's Avatar
Leaving the head and oil pump as far as i know..... shells are probably lead copper etcetc.
Rob,
just edited last post.
oil smelling of fuel would be the only indication of blow by but could it cause problems like i've had? and at what point would you say fuel in oil was excessive if any?
Old 13-12-2010, 09:46 PM
  #92
Rob_DOHC
Rob_DOHC's Avatar
Fuel contamination would have to be pretty damn excessive for that mate, cam cover off would probably give you a clue as to whether your problem is anything to do with the top end.
I don't really know how to diagnose how much fuel is in the oil, if it smells strongly of petrol its in there.
From what i have heard your in safe hands etc. And i really couldn't diagnose problems etc with out having it all in front of me to look at
Best of luck with it mate and let us know what they find
Rob,
Old 16-12-2010, 09:28 PM
  #93
BRAM
BRAM's Avatar
Is there any luck with this car then? have you found out where the filings are coming from?
Cheers Bram
Old 17-12-2010, 05:27 PM
  #94
tiny2white
tiny2white's Avatar
Spoke to Luke today and he's confirmed damage to oil pump case which is alloy turbo Is being rebuilt hope to get it back next week and have some good results to post, and a car to drive over the holidays!
Old 17-12-2010, 05:33 PM
  #95
GaryHurn
GaryHurn's Avatar
good news , its a nice car that sierra had a good look around it on monday
Old 17-12-2010, 06:26 PM
  #96
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Internal damage? They all end up with score marks BUT the oil pump is before the main oil filter so anything coming out of the pump isn't the problem!
Old 17-12-2010, 06:42 PM
  #97
Correct there was also some other bits of metal in the sump...
cheers danny
Old 17-12-2010, 07:22 PM
  #98
tiny2white
tiny2white's Avatar
cheers danny
So what you saying Danny what Luke is telling me is not correct?
So far he's told me shells look fine to stay, your suggesting new ones?
Luke says change oil pump and all good to go but your last post surgests otherwise.
Old 17-12-2010, 07:29 PM
  #99
I was agreeing with martin as he said its not whats come from the oil pump thats the problem and his right..
Imo the shells should be changed but if luke wants to use them id tell him you want new ones...
They can go again yeah but for the sake of Ł100 or so go with new ones mate..
cheers danny
Old 17-12-2010, 07:32 PM
  #100
JonnyBravo
JonnyBravo's Avatar
Surely if its had a shed load of swarf go through the engine it neds pulling apart completely ?
All galleries, hoses and coolers need to be checked I'd of thought so guarantee it doesn't happen again ?
Old 17-12-2010, 07:41 PM
  #101
Thats what id rather do!!!
cheers danny
Old 17-12-2010, 07:44 PM
  #102
Received 1,044 Likes on 998 Posts
Just read the full thread,thats shit news about the turbo been fooked.I hope it all goes back togther soon and it gets the figures your after.
Old 07-01-2011, 08:57 PM
  #103
tiny2white
tiny2white's Avatar
Well I'll be taking another trip to EP to torrow morning.........
To collect my car!
I just want to say thank you (B4 i pick it up) to both Luke and Danny for putting up with ME while they have had it in their care.
Got some really good figures off Luke over the phone yesterday and today and now i cant bloody wait to get hold of it.
Would a nice dry day be to much to ask for???????
Old 07-01-2011, 09:16 PM
  #104
GaryHurn
GaryHurn's Avatar
What did it make? It's on link now???
Old 07-01-2011, 09:27 PM
  #105
tiny2white
tiny2white's Avatar
yeah on link now 432bhp 465ft lbs, Luke tells me it was making 152ft lbs @ 1200rpm and full power is made @ 4500rpm!!
Old 07-01-2011, 09:33 PM
  #106
t3 dan
t3 dan's Avatar
sounds good mate bet you cant wait to get it back
Old 07-01-2011, 09:39 PM
  #107
tiny2white
tiny2white's Avatar
really cant wait its just not the weather for all that and 2wd! so will be driving miss daisy untill i get a feel for it
Old 07-01-2011, 09:40 PM
  #108
bigchez
bigchez's Avatar
Shedloads of torque - nice result
Old 07-01-2011, 10:06 PM
  #109
rsmark86
rsmark86's Avatar
sounds a good car
Old 07-01-2011, 10:53 PM
  #110
cossie daz
cossie daz's Avatar
sounds like Danny and Luke have done a great job
ive never used them but im sure i will do in the future as im very local
www.westsussexrsoc.co.uk
Old 07-01-2011, 10:57 PM
  #111
J1mbo
B1mbo
J1mbo's Avatar
What size restrictor is used?
Old 07-01-2011, 11:07 PM
  #112
tiny2white
tiny2white's Avatar
45mm restrictor
Old 07-01-2011, 11:10 PM
  #113
J1mbo
B1mbo
J1mbo's Avatar
Cool!
Old 07-01-2011, 11:29 PM
  #114
Miller 3
Miller 3's Avatar
this back to standard cr now then?
Old 07-01-2011, 11:31 PM
  #115
vaughant
vaughant's Avatar
Was it just the oil pump causing the swarf in the end Danny or something more sinister?sounds another great job by ep.
Old 08-01-2011, 05:04 AM
  #116
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
absolute cracking results there and impressive torque bet its going fly on the road
Old 08-01-2011, 05:10 AM
  #117
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I hope you enjoy your drive home.
What was wrong with the engine in the end ?
Steve
Old 08-01-2011, 07:38 AM
  #118
carlo
carlo's Avatar
Nice one mate
Old 08-01-2011, 07:58 AM
  #119
GaryHurn
GaryHurn's Avatar
super results
Old 08-01-2011, 08:57 AM
  #120
vaughant
vaughant's Avatar
I was just thinking,150 odd ft/Lb is a standard Rs turbo at full torque at just above idle!!!!immense!!!!You could just waft about in that never really leaving 4th if you were feeling lazy one day,
Quick Reply: Enhanced Performance Tomorrow
