Any tips for sealing a leaking alloy/rim????
Right, joking aside, I got a set of replacement rims and winter tyres for my M5, but one of the rears is leaking and I keep having to pump it up, is there any quick and easy things I can do to stop or minimize it?
Just to be clear, it's definately the rim and NOT the tyre, as these are brand new.
Could be a dirty rim where the tyre seals, might just need the tyre off and clean the rim.
Could be a leaking valve.
Have you had the wheel and tyre in a bath of water (kids paddling pool) to see exactly where it's leaking?
Just cause the tyre is new doesn't guaranteee it's perfect.
Cheers,he came round and picked it up last night and will try and sort it today, i hope it's something simple. He did say he'd put a wheel weight on the inside edge so would remove that and see if that cures it as sometimes they can effect the seal.
Chop, yeah you can easily get wheels fixed/welded etc, let me have a look sometime and i'll be able to reccomend somewhere.
Thanks for the responses.
S1 Database Editor
My dad had a problem with one of his tyres. Eventually they removed the tyre completely and found a raised section of old build-up. They got a flapper wheel in a drill and cleaned off all the old crap from this area.
Redumbdancy
Roj - I wonder if some tyre foam would be good for a temporary fix?
Wire brush the seal area job done
My wheel was leaking 15 psi every 12 hours
Sorted now £6
07-10-2015 12:56 PM
