mk5 fiesta zs
i have one with my old puma 1.7 engine in it and that is 200 miles of 150k on the clock and i dont hang around in it so that aint bad. But i changed the engine coz the std one had a piston and rod missing coz it had jumped ship out the back of the block
That's what I meant when I said abuse, I didn't mean they didn't like being driven hard.
Depends on how many teeth the belt jumped.. have had a zetec jump 3 teeth on the belt and was alright.
You might be lucky !
Have you tried filling up the chambers with fluid to see if it leaks past the valves, only safe way to check if any of the valves are bent !
engines are so cheep, id want to change it,
i had one in that i put a new head on as the belt had snapped, there was tiny marks on the piston, 400 miles later number three piston literally disintergrated.
you might be very lucky, a head gasket is 30 quid.
id look at this as a perfect chance to upgrade to puma engine
I had the head checked out it had very slightly bent 2 valves but I had them all replaced to be safe. Didn't want to change the engine as it's only done about 61k. I'm just putting it back together then it's up for sale. It's a 2002 car so should fetch decent money when done
Steve Escos
01-10-2015 06:57 AM
