batt light comes on when heated screen on
got a wierd problem
when i turn my front heated screen on the batt light comes on, i can have everything on and not a problem and its only when the front screen is on the batt light comes on
would this be an alternator problem or a bad earth for the screen, ive checked everything and everything seems fine just carnt understand what it is and was wondering if anyone else has had this problem its on a sierra
Put a voltmeter on next time and see if the voltage is dropping sufficiently to show no charge, as jon says relay for front screen is energised one side by the live output from the alternator "ind"(dash warning light wire terminal).
I suspect a alt problem rather than wiring.
Resident Wrestling Legend
the not screen loom is stand along and only connects to the ecu to raise the rpms when it's switched on
it also won't work unless the engine is running to save the drain on the battery
so simply get a meter across the terminals with the screen off, then switch it on and see what happens
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
