Focus CGI blocks
Old Nov 7, 2010 | 07:25 PM
Luca's Avatar
Luca
Lukesville
Default Focus CGI blocks
Are these still readily available?
Old Nov 7, 2010 | 07:27 PM
RONNIE AMIS's Avatar
RONNIE AMIS
aint that what they use in films?
Old Nov 7, 2010 | 07:30 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
I bought mine from Burton Power, was around Ł800 from memory.
Honestly though, Zetec blocks have run to 600bhp in standard form. Also, buying a new CGI block it will be 'green' and not have the benefits of heat cycling etc.
Old Nov 8, 2010 | 07:30 PM
Luca's Avatar
Luca
Lukesville
This is the thing...the unknown!
Lend me your block please young Will
Old Nov 8, 2010 | 07:39 PM
creator's Avatar
creator
luke i belive jano still has one
Old Nov 8, 2010 | 07:49 PM
RAT8OY's Avatar
RAT8OY
Luke,
I also hear that your machine guy won't thank you as any machining will blunt their cutters due to the hi carbon content.
Not sure they are a straight swap over with water pumps and stuff but I might be wrong.
Why not just liner a standard high mile block? Are you building another engine?
Old Nov 8, 2010 | 07:50 PM
HockeyNomad's Avatar
HockeyNomad
Burton Power had a batch in last year but i beleive these are all gone now,
and mine is staying in my car lol,
Old Nov 8, 2010 | 08:00 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
There was one on eBay a couple of weeks ago, came with crank,pistons,rods,bore liners and the spacer plate for the head and some other bits, was going for
1500, I will see if I have it in my watching list on there
Old Nov 8, 2010 | 08:51 PM
JPA's Avatar
JPA
still in the latest burton catalogue came through my door last week
Old Nov 8, 2010 | 08:59 PM
nthorpey's Avatar
nthorpey
have one that needs final finish machining in my garage, may be for sale if i recieve a good offer that i can't refuse.
dug112y's Avatar
dug112y
passionford pro
there was one on here for sale few weeks ago....
Old Nov 8, 2010 | 09:30 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i no where there is one dout its forsale tho but dosent hurt to ask
Old Nov 8, 2010 | 10:06 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
hi luca , ians cousin worked for cosworth and when they finished the wrc program he got a lorry load of parts for a grand , 8 wrc blocks , 12 inlets , wrc wastegates etc . i was going to buy one but when looking at the block he said that there was that much machining and custom parts to fit and build he simply said it aint worth the hassle. like dan said just liner your standard block. my engine made 522bhp @30 psi in 2006 and theres only paul johnson who has bettered that with the same amount of boost and that was only a few months ago. iam sure you realise there are more mods and parts that have advanced in the last 4 years. 600+ bhp is acheivable more easily with the new parts available
cheers paul
Old Nov 8, 2010 | 10:57 PM
XRT_si's Avatar
XRT_si
I know someone that's got a Nikasil linered Zetec sitting there, which he'd sell too ; )
Old Nov 8, 2010 | 11:51 PM
Big Will_'s Avatar
Big Will_
Not the case
I warned my machinist about this and when I went to pick it up he said it had machined as normal
There are two CGI blocks available - one is a direct replacement for the Zetec E block (blacktop) - water pump in same place etc. Only missing one boss on the rear for a knock sensor as i found.
The other one is the heavily externally machined version that was used as a WRC block. that had all non used bits machined off to reduce weight, then it had about 15mm machined off the deck height, wet liners installed and then a space plate to go over the top of the liners - wouldn't even consider trying to build one of these unless you've got a complete WRC engine spares package!!
Old Nov 9, 2010 | 08:52 AM
XRT_si's Avatar
XRT_si
I spoke to him earlier said he would
But I've got a feeling that his is a prorper WRC block I.e. As Will said needs shit load of work.
Old Nov 9, 2010 | 03:35 PM
Luca's Avatar
Luca
Lukesville
Nothing concrete yet just looking into options plus the perks of going with the CGI block.
Have found one now, just awaiting on details before I make any decisions.
Thank you for the response
Old Nov 9, 2010 | 04:16 PM
J1mbo's Avatar
J1mbo
B1mbo
cheers paul
I don't know any one who has thus far broken the 550 mark without breaking a zetec in this country, getting to 570 isn't the easiest of things and a jump from 522 to above 570 is alot ! What do you think yours will make next time around ?
Old Nov 9, 2010 | 06:33 PM
zetaboostboy522bhp
at the same boost 30 psi iam hoping for around the same but iam going upto 35psi so i want 600+ bhp, this would be very nice lol but we will have to see. i ran out of injector last time with only 4 and only a mild inlet cam.
now we have 8 injectors , dry sump , new inlet and both inlet and exhaust cams are going a tad more aggresive
so i will see you next year , knowing my luck it will probably go pop
cheers paul
Old Nov 9, 2010 | 06:36 PM
J1mbo's Avatar
J1mbo
B1mbo
cheers paul
Sounds good to me ! You bringing it back to the dyno then be good to see it do the power
Old Nov 9, 2010 | 06:47 PM
szabyk RST's Avatar
szabyk RST
how strong can this stuff?(as a factory)
the silver top already powerful as black top...
can someone cracked block or crank???
I have already done several times 13-14K RPM.......(a few seconds)
but can not find fault..
Old Nov 9, 2010 | 06:52 PM
Miller 3's Avatar
Miller 3
cheers paul
Not round brum way by any chance? i knew a lad and his mates had a load of gear like that a few year back! might have a pic some where.. was like aladdins cave lol
Old Nov 9, 2010 | 06:56 PM
zetaboostboy522bhp
yep going to ians first in the new year so we can look at machining the block and head for m12 studs then if possible it will be off to mk motorsport for the machine work then to your old mans as personally i think hes one of the best if not the best and we had a right laugh last time. hoping for around feb / march time
cheers paul
Old Nov 9, 2010 | 07:01 PM
zetaboostboy522bhp
no he lived in huntingham way on i think, but i think i may know of the bloke your on about as i wanted a wrc exhaust manifold and someone put me in touch with him, he had loads but wanted Ł900 so i built my own
cheers paul
Old Nov 9, 2010 | 07:06 PM
J1mbo's Avatar
J1mbo
B1mbo
cheers paul
Sounds good to me !
Old Nov 9, 2010 | 07:26 PM
Luca's Avatar
Luca
Lukesville
Keep us updated Paul, may even head up when you are there if you dont mind.
Old Nov 9, 2010 | 07:35 PM
Miller 3's Avatar
Miller 3
cheers paul
It was a pair of twins with ginger hair round brum way.. that's all i know lol
but yer those ex manifolds were the real deal made from incanol (sp)
Old Nov 9, 2010 | 08:11 PM
zetaboostboy522bhp
YOUR MORE THAN WELCOME MATE , I WILL LET YOU KNOW
Old Nov 9, 2010 | 08:49 PM
clarke5700's Avatar
clarke5700
yup its the wrc block but he spoke to "close friend" and have gone over dimentions of the spacer plate ectect
Old Dec 22, 2010 | 07:13 PM
Cosworthzetec's Avatar
Cosworthzetec
Hello
I am the owner of the linered wrc block from ebay, if anyone should have interest can contact me via pm.
bye chris
Old Dec 22, 2010 | 10:05 PM
Luca's Avatar
Luca
Lukesville
I already sourced a new one
Post a link for others to see though mate if you have one up for sale.
Old Dec 23, 2010 | 11:06 AM
XRT_si's Avatar
XRT_si
Luke - Honest question; Why do you need a CGI block?
Old Dec 23, 2010 | 11:53 AM
Big Will_'s Avatar
Big Will_
I know of at least one engine that's dyno'd over 600bhp on a standard Zetec block...
Luke - if you really want to spice things up. PM me. I've just about finished sorting out a stroker kit that will take normal aftermarket Zetec rods, pistons, bearings etc. but will take capacity to just over 2.2 and still safely rev to 8000rpm
Old Dec 23, 2010 | 12:04 PM
crazycage's Avatar
crazycage
thats got me interested .
Old Dec 23, 2010 | 12:06 PM
sas's Avatar
sas
should be good!
Im just about to sell my CGI blocked engine (84.6mm bore) in fact the whole engine and car.
Simon.
Old Dec 23, 2010 | 12:42 PM
Luca's Avatar
Luca
Lukesville
Simon - Honest answer; I dont know!
600hp Pft!
Just seemed logical to buy one
Il speak to you shortly mate.
Old Aug 20, 2011 | 03:28 AM
focusracingaustralia's Avatar
I know this is an old thread but, just thought I would ask anyway
Does anyone have a Cosworth Zetec WRC cgi block for sell????
Old Aug 20, 2011 | 09:18 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
some people still have a couple of blocks. You need to search
Old Aug 20, 2011 | 09:41 AM
I have been looking but no one wants to part out their motor
If anyone want to sell 1 please PM me
Old Aug 20, 2011 | 04:40 PM
nthorpey's Avatar
nthorpey
I got one that needs machining, make me an offer I can't refuse
