WRC vs 4wd
Old 04-11-2010, 05:15 PM
herbst 1
herbst 1's Avatar
Default WRC vs 4wd
Someone knows the advantages from a wrc exhaust manifold vs 4wd manifold ? How will a TT T38 perform with the wrc manifold ?
Old 04-11-2010, 05:57 PM
J1mbo
B1mbo
J1mbo's Avatar
It will perform well
The wrc is a even pulse manifold
The last t38 engine on wrc manifold made 460 bhp
Old 04-11-2010, 06:19 PM
herbst 1
herbst 1's Avatar
Thanks. Is the 4wd a even pulse manifold to ?
My Mountune built engine is already 450 bhp with the 4wd manifold, do you think the wrc manifold would make it better
Old 04-11-2010, 06:22 PM
c20tbo
c20tbo's Avatar
Ive a good manifold for sale in the parts section.
Old 04-11-2010, 06:37 PM
J1mbo
B1mbo
J1mbo's Avatar
No 4x4 has different legnth manifold pipe work,
The wrc would see you small gains yes
Old 04-11-2010, 06:47 PM
herbst 1
herbst 1's Avatar
Thanks again
So t38 and 4wd manifold are a match made in heaven or will 2wd be better ?
Old 04-11-2010, 06:51 PM
J1mbo
B1mbo
J1mbo's Avatar
Very good together ! We do alot of these engines with 4x4 manifold and t38 works well
Old 04-11-2010, 06:59 PM
herbst 1
herbst 1's Avatar
Old 06-11-2010, 07:37 PM
herbst 1
herbst 1's Avatar
What comp do this engines have ?
Old 06-11-2010, 07:57 PM
Sonic Boom
Sonic Boom's Avatar
Jimbo what's a Pulse Manifold?
My tubular manifold looks very similar to a WRC one:
Rich
Old 06-11-2010, 08:03 PM
J1mbo
B1mbo
J1mbo's Avatar
Even length pipes ! Yes yours looks based around that !
Old 06-11-2010, 08:09 PM
herbst 1
herbst 1's Avatar
Hello j1mbo, please answear my question to
3 rows up...
Old 06-11-2010, 08:13 PM
J1mbo
B1mbo
J1mbo's Avatar
Sorry herbst
Do you mean compression. Ratio of a wrc engine ? They can be around the 10:1 cr mark !
Old 06-11-2010, 08:21 PM
herbst 1
herbst 1's Avatar
No, the compression of the 4wd manifold and T38 engines
Old 06-11-2010, 08:25 PM
J1mbo
B1mbo
J1mbo's Avatar
Depends who you use to map it, speak to the person who will map it and see what they advice, but slightly below the standard 8:1 cr is the norm
Jim
Old 06-11-2010, 08:30 PM
herbst 1
herbst 1's Avatar
Thanks again and again .
The engine is finished long ago, it's a mountune engine with roller barrel, 8,2:1 comp, 4wd manifold and TT T38.
Why do you think Mountune went for slightly higher comp ?
search youtube "mountune escort cosworth"
Old 06-11-2010, 08:33 PM
Kverna
Virgin-popper
Kverna's Avatar
*snip*
Old 06-11-2010, 08:36 PM
J1mbo
B1mbo
J1mbo's Avatar
Is it grey escort cosworth ? I see it on there looks very nice, sounds a nice spec engine !
Old 06-11-2010, 08:42 PM
herbst 1
herbst 1's Avatar
Yes it is, why do you think Mountune went for slightly higher comp ?
Old 06-11-2010, 08:43 PM
J1mbo
B1mbo
J1mbo's Avatar
They are used to doing rally engines so probably try to stick to quite a high compression ratio, I guess, other wise I don't know !
Old 06-11-2010, 08:48 PM
herbst 1
herbst 1's Avatar
Thanks again
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
IainRS1700T
25-09-2015 06:44 AM
focus2351
09-09-2015 09:33 PM
Quick Reply: WRC vs 4wd
