What could be causing high emissions....
Old Nov 3, 2010 | 02:00 PM
cfoster's Avatar
cfoster
Default What could be causing high emissions....
One of me missus' colleagues has a Fiat Seicento and its just failed the MOT on emissions. They said they can't trace it?!! Any ideas what could cause the high emissions except for the Cat and Lambda Sensor?
Old Nov 3, 2010 | 02:02 PM
rs-tuner's Avatar
rs-tuner
Blocked air filter
lead_foot's Avatar
lead_foot
is awesome
Failed on CO? HC? Lambda?
Take it for a rag to get the CAT nice and hot?
Old Nov 3, 2010 | 02:14 PM
cfoster's Avatar
cfoster
Just waiting for a copy of the emissions sheet, will put it on here in 5!
Old Nov 3, 2010 | 02:29 PM
cfoster's Avatar
cfoster
Here is the fail sheet....
[img][/img]
cfoster's Avatar
cfoster
Old Nov 3, 2010 | 02:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Any chance of a clearer one mate so we can read the figures as I cant make them out. Will give you my opinion gladly once I have them.
Old Nov 3, 2010 | 04:04 PM
lead_foot's Avatar
lead_foot
is awesome
As above, can't see the figures
Old Nov 3, 2010 | 04:09 PM
XRT_si's Avatar
XRT_si
Coolant temp sensor?
Old Nov 3, 2010 | 05:09 PM
cfoster's Avatar
cfoster
ill see what i can do, hopefuly the missus brought the printout home so ill scan it!
Old Nov 4, 2010 | 07:15 AM
cfoster's Avatar
cfoster
Here you go Stu. Thanks
Old Nov 4, 2010 | 07:24 AM
coco16i's Avatar
coco16i
Going by that reading's i would say the catalyst aint hot enough and is not working properly yet.
The tester has bypassed the engine temp so cant see how warm the engine actaully is.
The readings are not terribly high and would probably be a lot higher if the catalyst was goosed !
Make sure its had a good hard run before getting tested again as most times a high CO reading is due to the engine not being hot enough.
If you have it roasting hot and it fails again your probably looking at a new catalyst.
Old Nov 4, 2010 | 08:45 AM
I concur. Is this a car used primarily for short journeys by any chance?
Old Nov 4, 2010 | 12:07 PM
cfoster's Avatar
cfoster
I think she travels about 10 miles each way to work? I wouldnt want to travel any further in something that small!!!! Is it worth her replacing the cat? She said this morning that if its going to cost too much she may as well sack it in and buy a new car?!
Old Nov 4, 2010 | 12:23 PM
scoooby slayer's Avatar
scoooby slayer
go and warm it up and pop it off the limiter a few times then take it back should get a free retest if you get back within 7 days
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
boeb
Jan 9, 2020 05:11 AM
