my launch problems, answer inside :)
Old Nov 2, 2010 | 05:04 PM
scoooby slayer's Avatar
scoooby slayer
Default my launch problems, answer inside :)
its been bugging me what im doing wrong after turnover, paulo etc saying launch hard so ive just been out and done it. no faffing about with the clutch just 7k revs clutch bite and then let her go and done the quickest 0 - 60 ive ever done
il be honest that is the first time ive launched a car with absolutely zero mechanical sympathy and i loved it
anyways i took the gtech for comparisons and it shows just how much i can gain on the rubbish launches ive been doing.
i think i may have to trailor the car to pod next time so as its not in my mind that ive got to get home in it, if i can just do what ive done at pod i think i should manage a mid to low 11 as the 1.7 60ft i did felt proper quick from in the car.
ive got an electronic hurst roll control line lock on the way from america aswell so i will be able to flick her in rwd and do a burnout to
Old Nov 2, 2010 | 05:13 PM
Luca's Avatar
Luca
Lukesville
Nice work mate!
Im guessing 2011 it is back to Pod
Old Nov 2, 2010 | 05:16 PM
scoooby slayer
Originally Posted by Luca
Nice work mate!
oh yes mate i cant blame the car it is all me lol
Old Nov 2, 2010 | 05:17 PM
turnover's Avatar
turnover
thats better mate and i believe you should run 11.5s or better,to be honest if you have a good clutch the gearbox,s are very strong and have often had 750hp thrown through one for over a year of track and drag ,So you should be ok
Old Nov 2, 2010 | 05:19 PM
turnover's Avatar
turnover
oh and if you feel dizzy for a split second when you launch ,you know youve got away well
Old Nov 2, 2010 | 05:21 PM
phil_rs's Avatar
phil_rs
yam yammer
You'll be fine giving it death mate, it's not a Ford after all!!!
Luca's Avatar
Luca
Lukesville
As my mate Jim said to me,
"its simple, be....
"BRUTAL"
I was perhaps a little too brutal
Old Nov 2, 2010 | 05:23 PM
turnover's Avatar
turnover
"its simple, be....
"BRUTAL"
yeah but you need a clutch lol
Old Nov 2, 2010 | 05:24 PM
Luca's Avatar
Luca
Lukesville
Its all your fault for pm'ing me!
Old Nov 2, 2010 | 05:29 PM
scoooby slayer
i learned something else earlier aswell i dont need to load it up on the handbrake i can do it without just hit 7k, find clutch bite then lift left leg and drop the hammer.
i did a hard loading it up on the handbrake once and got bad clutch slip when i pulled away i must of overheated it, i done 4 launches after that though and it didnt slip so no damage done.
Old Nov 2, 2010 | 05:32 PM
scoooby slayer
going by the time i lost that run could of technically been an 11.4
i think the only answer is a trailer so i dont granny launch it again lol
Old Nov 2, 2010 | 06:22 PM
turnover's Avatar
turnover
get tyres on .clutch and im sure you will be in the mid 11s or better
Old Nov 2, 2010 | 07:53 PM
cossie0_4's Avatar
cossie0_4
just put a switch between the fuse and it will be rear wheel drive m8
Paulo P's Avatar
Paulo P
1.7 0-60ft times will help massively and that is a huge improvement and you should see better with a properly prepared surface on a good warm day You must have been chuffed with the way it launched
Old Nov 2, 2010 | 08:17 PM
scoooby slayer
already in mate i just need to get my line lock fitted now so i can do a burnout before the run.
Old Nov 2, 2010 | 08:21 PM
scoooby slayer
i am mate im grateful for all the little nudges ive had to launch it almost off the limiter it was awesome
i just hope it doesnt brake when i do it at pod
its the front diff i worry about failing and potentially taking the engine with it
Old Nov 2, 2010 | 08:22 PM
lead_foot's Avatar
lead_foot
is awesome
Awesome launch mate, wish my S14 could launch like that. Probably do another gearbox trying to launch like that.
Jump your left foot from the clutch to the brakes quick as while your right foot is flat to the floor. RWD burnout, no line lock need.
Old Nov 2, 2010 | 08:26 PM
scoooby slayer
i dont wana do that mate as it just loads up the rear brakes like that and strains the clutch and well everything imo as it cant be helped that the rear brakes will be on a bit, proper hurst roll control kit is on its way from the states so its all good
Old Nov 2, 2010 | 08:37 PM
Ginger Will's Avatar
Ginger Will
Massive reduction in the 0-60fts and 0-60mph!!
I would bet 90% of people will never ever do the quoted 0-60 from the manufacturer because they are scared to break it!
Old Nov 2, 2010 | 08:56 PM
xr4x4rs's Avatar
xr4x4rs
you should be able to do hard launches and drive the car home as the std transmission is pretty dam strong, my mates at 608bhp on std gearbox and he launched his off the limiter everywhere
and to go rwd isnt it just a case of pulling the abs fuse out?
Old Nov 2, 2010 | 08:59 PM
scoooby slayer
yes mate i got it on a switch already and got line lock ordered, the other option is get a pair of mickey thompson streets for the back and just drag race in rwd, its a possibility as the front diff does worry me a bit if it explodes and takes the sump with it
Old Nov 2, 2010 | 09:07 PM
xr4x4rs's Avatar
xr4x4rs
i do agree but thats like cossis aswell, though the skyline stuff is a hell of a lot stronger, i dont know anyome with a skyline who hs destroyed a front diff, ive seen them destroy os gearboxes but not a diff, its also a reason im looking into see if one can be modded to fit on a cossie sump
Old Nov 2, 2010 | 09:20 PM
Paulo P's Avatar
Paulo P
To be honest with you the front driveshafts are the weak link in the transmission so you're more likely to break one of those before the diff One of my mates broke a front driveshaft at the pod the week after I ran it at Shakespeare I wasn't launching it because I didn't want to break it 2 weeks before Time Attack so he broke it one week before Time Attack and 2 days before my trackday at Brands lol Abbey soon fixed it though
Old Nov 3, 2010 | 07:35 AM
scoooby slayer
that is a comfort to know mate im in tha aa to so i guess they would get me home, it doesnt help as i was at pod last time on my own so would of needed a stranger to help me push it lol
Old Nov 3, 2010 | 07:38 AM
scoooby slayer
its definitely worlds apart from the cossie drivetrain, i mashed loads of 2wd rear diffs and the skyline has seen more hard drivetrain hard work than all my cossies put together and touch wood nothing has broken yet ! fingers crossed
Old Nov 3, 2010 | 08:10 AM
zippyobrien's Avatar
zippyobrien
Well done mate. Told ya brutal the way forward. Need launch control now to see some boost of the line
Old Nov 3, 2010 | 08:20 AM
Have a word with wenny for tips on launching. He knows how to get his cars of the line.
Old Nov 3, 2010 | 08:57 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
7k and foot off the clutch sideways is definately the way to go!
Old Nov 3, 2010 | 12:41 PM
scoooby slayer
that was the problem mate i think with launching at 4k it wasnt seeing hardly any boost, it does at 7k though i saw 1.9 bar spike on the 0 - 60 mph in 3.3 seconds run
Old Nov 3, 2010 | 12:44 PM
scoooby slayer
i gotta say it did feel awesome doing just that, brutal on the car but good fun and quick
Old Nov 3, 2010 | 02:36 PM
Paulo P's Avatar
Paulo P
My mate drove the car from Santa pod to me in High Wycombe and I drove the car from High Wycombe to Abbey Motorsport down near Gatwick on 3 wheel drive Only problem was torque steer when you booted it
Old Nov 3, 2010 | 04:39 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
My mates escos was running 12.0 at pod with 2.0 60fts he chucked me the keys and said have ago I said I dint want to break it mate! He said f.%k it I'm not botherd !
I held it at 6k and side steped the clutch!
Which resulted in a 1.7 60ft and an 11.6 1/4 mile!!
I'd say just go for it on your next outing at the pod!!
Old Nov 3, 2010 | 04:55 PM
Chip's Avatar
Chip
Not uncommon for a gain at the 60ft marker in terms of time saved to equate to something in the region of 150% of that gain off the ET
Ie taking 3 tenths off a 60ft can take 4 or 5 tenths off the ET in most cases.
Old Nov 3, 2010 | 08:49 PM
scoooby slayer
im gonna do it next time mate for sure no more fucking around lol
what power was the escos ? 0 - 95 mph in 7.5 seconds aint shy is it
Old Nov 3, 2010 | 08:50 PM
scoooby slayer
lets be honest mate all i can do is loose time, it must be physically impossible for me to gain anymore lol
Old Nov 3, 2010 | 08:57 PM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Around 500hp mark gt3078r potted head cams ect msd live map it's very sharp indeed!
Old Nov 4, 2010 | 08:04 AM
scoooby slayer
cool about where i should be at then as im abit heavier
does he come on here at all mate ?
his terminal and weight also comes out pretty accurate on my chart from rips
add 0.5 to the et as its not a drag car and 119 mph and 11.6 comes in at 400 whp which would be about right working on 1400 kg with driver
Old Nov 4, 2010 | 10:09 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
yes his name on here is turbo mook
155lee
Sep 6, 2016 11:10 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
Flateric_2002
Sep 15, 2015 08:41 AM
hopper350
Sep 4, 2015 12:53 AM
