Bike Throttle Bodies
wondering anyone here use bike throttle bodies on a zetec st engine. Looking for a set with near 50mm outside diameter and that can be split to match plastic manifold
An eye for detail...
I think most newer bikes are using bigger bodies than they used to. I believe the post-07 cbr's use 49mm or summat.
Jenvey have a brilliant read about sizing. 45mm are more than enough for my 1.8blacktop. You just have to make sure they are correct length and taper
Thanks guys think ya slightly miss under stud looking for something with around 42mm choke but 50mm outside diameter as thats size of rubber on inlet have ecu and all just cant afford jenveys at mo
mk3ste
17-10-2021 10:09 AM
