225/40/18 on a saph
225/40/18 on a saph
on a 8j wide wheel, et 42 ( but with a 5mm spacer so effectivly et37 )
How much trouble am i going to have getting them on my 4x4 saph ?
I would go down too a 215/35/18 but if i dont have to change the tyres i dont want too.
Tried a set of Comps from an escos on my sapphire, tyres were 225/40/18, no chance of fitting on mine, to wide and to big
Tyres were too large to fit the arches correctly
Heres how they looked tho.
So liked the look of them, want some sapphire fitment ones.
You would need 215/35/18 tyres to fit.
Just bought myself an arch roller lol
James, I would but my fronts are rusty and shit and I can't undo the locking screws otherwise I would. ( see wanted thread for coilovers lol )
Jason, do you know what offset they were, look at least et20.
I had 215/35/18 tyres on my last set of 18s but this have come with 225/40 so want to try and use them if I can
1st to 200 without NOS
I think the 225/40 tyres would probably need quite a bit of arch work to clear.
On my 3 Door the tyres were 235/40/17, fitted fine.
Width is ok, just the profile will be the issue
I am with the similar problem , i want fit a 18" in the sapph but not in 215. I prefer 225x40x17 that 215x35x18, if are possible fit the 18" with 225" in sapp will be a nice option!
What is the best option for nice handle ?
The problem is the limit tires that you have in 225x35x18 .... buahhhh toyor888 not, slicks not, yokohama advan a048 not , :S only street tires .
Happily retired
I have bigger than that on the rear, i would not change from 17's on the front as it changes the handling.
Heres 235/40/18
& 225/40/19
The arches need completly to be cut away to get these on but worth it IMO.
Heres 235/40/18
& 225/40/19
Happily retired
Hi
I run 8x18", offset 33 (should have gone for a bit lower offset .. ..28/29...) with 225/35 tyres, std type suspention (koni/eibach) and sleightly rolled arches ...
Nope ... I even did track days without any problems, ... two things I did forget is car is lowered and that the rear end has been altered a little .. dont know how to explain ... but if you look at the pic's the angels on the rear wheels are more upright than normal on a lowered sapp.
ive got a set of gold revolution wheels with tyres for sale if anyones interested PCD 108 ET13 with 225/40/18 tyres excellent condition ?
they are the ones on my FRP
Interesting thread this, I'm sticking with 17" and 225/45 X17 front and 235/45X17 rear, methinks some big hammer marks on the arches will help ?, this is on a 7J rim etc 36.
Haven't fitted/tried yet so don't know whether need to mill away some inside lug face yet or not.
Well I've just had a quick roll of the arches and I think the rears will fit but the fronts are so likely. Just waiting for a newer set of front coilovers to turn up so I can raise the front alittle... there maybe a chance of them fitting altthough on the front its very very close to the coilover
Russ Payne
25-09-2015 08:29 PM
