Focus ST3 Problem
Old Nov 1, 2010 | 01:44 PM
davidst357's Avatar
davidst357
Default Focus ST3 Problem
Hi all,
I have a Focus ST3 2007 57 reg done 27k and on start up from cold it does a loud screeching noise then after 20 seconds or so settles and is fine.
Anyone shed any light on this? or had the same problem?
Evans halshaw Ford want £50 just to take a look which I think is scandalous!
Any help appreciated
Cheers David
Old Nov 1, 2010 | 01:52 PM
Sp3no's Avatar
Sp3no
Aux belt not tensioned correctly or something is causing it to slip?
Old Nov 1, 2010 | 01:56 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Hello welcome to pf...
Old Nov 1, 2010 | 02:09 PM
martysmartie's Avatar
martysmartie
Almost defo a belt as said, always worse when cold, probably a replacement belt required, you could check the play on the longest run of the belt to see but I should think it's auto tensioned.
Martin
Old Nov 1, 2010 | 02:15 PM
davidst357's Avatar
davidst357
Thanks guys if it is that what you talking for a new belt pricve wise?
also a few things on the net saying it could be the engine manifold gasket???
Im getting it looked at on friday so will keep you posted.
DJMST's Avatar
DJMST
SHELL GARAGE VIP
It is auto tensioned,check your air-con pump isnt siezed
Old Nov 1, 2010 | 04:08 PM
RichieST's Avatar
RichieST
try spraying a little bit of water on the inside of the belt before you start it up, if the noise goes away or changes at all that will confirm its the belt!
Old Nov 1, 2010 | 05:17 PM
CarParts Express's Avatar
CarParts Express
New belt £16
http://www.carpartsexpress.co.uk/Foc...35-99-375-463/
Old Nov 18, 2010 | 01:18 PM
davidst357's Avatar
davidst357
Hi Guys,
I managed to get evans halshaw ford to take a look at my car for FREE yes FREE as they originally wanted £45 just to diagnose the problem and its turned out that its the Exhaust manifold that has a crack in it. They hopefully will cover it under the extended warranty fingers crossed! When its cold the crack is open then when it warms up the crack closes with the heat and thats why the screech noise stops! Hope the warranty comes good :-(
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
