YB bottom end rebuild torques
Testing the future
am doing one tonight and cannot find my manual.
Can anyone please tell me the required tightening torques for:
big end caps
main bearing caps
sump bolts
front cover bolts
crank pulley bolt
thanks in advance
big end caps
main bearing caps
sump bolts
front cover bolts
crank pulley bolt
thanks in advance
According to Ford Workshop Manual... (Verbatim, so can't get shouted at if something goes wrong )
Con rod caps to con rod : 55 to 60 Nm
Main bearing caps to cylinder block : 87,5 to 101 Nm (Note : Loctite 270)
Sump to cylinder block : Stage 1 : 8-10 Nm, Stage 2 : 8-10 Nm (Note: Bolts:Loctite 270, Gasket:Loctite 518)
Timing Belt Cover to engine - all bolts : 8 to 10 Nm
Crankshaft pulley to crankshaft : 122 to 135 Nm
155lee
24-10-2015 11:11 AM
