Intercoolers, and the effect they can have
Old 20-10-2010, 08:07 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Default Intercoolers, and the effect they can have
Just thought this might interest some people, its a correction factor used by many rolling roads as this is believed to be a reasonabley accurate conversion equation for different temperatures, its known as SAE J1349:
So on a 400bhp @25 degrees theoretical @990mb atmospheric pressure engine you would expect to see (assuming pressure stays the same):
396bhp @ 30 degrees intake temp (4bhp lost from theoretical on a good cooler)
381bhp @ 50 degrees intake temp (another 15bhp lost versus good cooler)
368bhp @ 70 degrees intake temp (another 28bhp lost versus good cooler)
And thats assuming that the different coolers flow air as freely as each other, if you start getting a flow restriction as well on the smaller/worse intercooler then this can easily be a far bigger difference.
Easy to see why most tuners bang on about the massive importance of a good intercooler!
Old 20-10-2010, 10:05 AM
Shonky
V6 Ka of Love
Shonky's Avatar
What's the general intake temp an intercooled YB engine would run when moving? The equation's 1:1 ratio is @ 25°C so keeping them below that will increase power would it not i.e. 4bhp increase @ 20°C?
Old 20-10-2010, 10:36 AM
Chip
Chip's Avatar
Shonky, yes if you can get the temp below 25 then the correction factor on the dyno will subtract power rather than add it (ie you are gaining an advantage from going colder)
40 degrees is about par for the course in general if you wanted to pluck a figure, but it really does depend on the ambient temp and the boost and the turbo and the intercooler etc.
Old 20-10-2010, 10:56 AM
chaffe
Turbocharging Technician
chaffe's Avatar
and if your in the north east of scotland today, its bloody snowing!
Old 20-10-2010, 11:05 AM
the mk1 kid
the mk1 kid's Avatar
Indeed! I remember seeing a cruising ACT of minus 1 at 80mph a few years ago, but it was a bit parky out!!
Tom
Old 20-10-2010, 11:15 AM
chaffe
chaffe's Avatar
lol
Old 20-10-2010, 11:36 AM
Chip
Chip's Avatar
On cruise if you have a 500 sort of sized cooler you should really be more or less at ambient, certainly within a few degrees.
Old 20-10-2010, 11:38 AM
chaffe
chaffe's Avatar
which is minus 2 today
Old 20-10-2010, 11:41 AM
ECU Monitor Enthusiast
Chip, while we are on the subject....
As you know, dyno's take an air correction measurement and this is always the ambient air temp of the dyno cell or air temperature going into the air entry point of the engine.
Now.. I have always thought this was ok for N/A cars as the air temperature actually going into the combustion process is about the same...but on turbo cars it isnt as the turbo upsets the air density into the engine by adding heat generated from compression.
Imagine the power levels if this sensor was placed after the turbo..LOL
Can you see what I am getting at ?
Old 20-10-2010, 11:46 AM
Chip
Chip's Avatar
Well yes of course that would send power up massively but falsely so as the probe needs to be reading the point at which it first enters the system, which is at the air filter not at the inlet manifold, would just be a total nonsense there, you may as well stick it in a cup of tea
Old 20-10-2010, 11:55 AM
In a cup of tea...You hear of some tuners doing this
(Not intended at a dig at anyone or company on this thread)
Old 20-10-2010, 12:00 PM
Chip
Chip's Avatar
Indeed, at some rollers if you are down on power its cause you made the tea too milky
Old 20-10-2010, 12:07 PM
Alg1k
Alg1k's Avatar
LOL
Old 20-10-2010, 12:12 PM
bezo
powered by K26
bezo's Avatar
-2.5 in blair atholl
Old 20-10-2010, 12:18 PM
phil_focus
phil_focus's Avatar
its very simple, the cooler the air entering the engine (post turbo) the denser it is and therefore the more fuel you can inject and the more power the engine will make.
simples
though HUGE intercoolers can increase turbo lag as theres a greater volume to pressurize so as with everything in life its a compromise.
Old 20-10-2010, 12:21 PM
Char1ie
Char1ie's Avatar
Or water injection when the intercooler size is limited.
Charlie
Old 20-10-2010, 12:22 PM
Chip
Chip's Avatar
simples
Well of course, everyone is aware that it makes a difference for those reasons, but its I thought it would just be interesting for people to see some figures showing how much rather than just knowing "some".
IME that doesnt really seem to be true to the extent you might think it would be, I guess the bottom line is that at even at low rpm like 3000rpm you are consuming 50 litres a second of air anyway, so a few litres difference in intercooler size really doesnt equate to anything very noticeable.
Old 20-10-2010, 12:38 PM
phil_focus
phil_focus's Avatar
it is a nice calculation and i do agree with you its nice to see actual figures, will even shock some poeple and make them realise how important intercoolers are AND the effect heat soak can have when you badly possition an open cone filter. hence the reason i run a pannel filter with uprated cold air feed in my focus.
your prob right too with the lag vs intercooler size but i've not had the oportunity yet to play with different sized coolers so the differences are prob very minimal.
Old 25-10-2010, 07:13 PM
chaffe
chaffe's Avatar
what about methanol injection lol
Old 25-10-2010, 07:20 PM
Rsmat
300+
Rsmat's Avatar
i love interesting stuff like this...cheers chip.
Old 25-10-2010, 07:44 PM
Danny @ Enhanced Performance
Danny @ Enhanced Performance's Avatar
It also proves that if your car has already made good power at a given act and you dont ever see it rise over this or atleast often then there isnt any need for a better cooler..
cheers danny
Old 25-10-2010, 08:31 PM
left hooker
left hooker's Avatar
so what do you think of the pro alloy 50mm intercooler chip
Old 25-10-2010, 08:34 PM
What power do you run???and was the car set up with that cooler??
cheers danny
Old 25-10-2010, 08:40 PM
Chip
Chip's Avatar
Ive not personally tried one mate, but on other people's cars they seem to work quite well, although not as well as the latest spec-r ones.
Old 25-10-2010, 08:49 PM
jammerrs
jammerrs's Avatar
you need to read a thread tabatha did a while ago about heat soak......very suprising results tbh
found it, https://passionford.com/forum/ford-s...teresting.html
Old 25-10-2010, 09:15 PM
phil_focus
phil_focus's Avatar
i've read that before mate, definately interesting but it only proves that an open cone is fine so long as its well possitioned. i've got a 2l focus. the air box is behind the batery and is totally boxed in so an open cone there even with a heat shield is uterly useless as there no air flow. a cold air feed will help at speeds above 30mph but as has been proved with the focus an open cone sucks in too much hot air when standing.
if i was to go open cone i'd have to move the battery to where the air box is, not a big job, and fit the cone just bellow where the battery was and pipe it accordingly. cant be arsed to do that at the moment though.
Old 25-10-2010, 09:22 PM
jammerrs
jammerrs's Avatar
i just re-read it and realised youd commented, ill slide away slowely back under my rock sorry mate.
Old 25-10-2010, 09:26 PM
left hooker
cheers danny
ive got 340 bhp and yes it was set up to it
Old 25-10-2010, 09:36 PM
Then imo its the best cooler you can have!!!
Get an act gauge mate and if your always in the 30s when driving its spot on,if it goes in the 40s when driving then id say you need a better cooler but i can gaurantee you it will always be plenty good enough for the job..
cheers danny
Old 25-10-2010, 09:44 PM
phil_focus
phil_focus's Avatar
haha dont worry mate its not a prob. if i moved the battery and routed a decent open cone i would gain a few bhp but i'm not sure what i'm doing induction wise. might be going throttle bodies. then i've got the heat soak issue to deal with even more
Old 25-10-2010, 10:05 PM
chaffe
chaffe's Avatar
methanol water injection is an effective way of reducing ACTs
Old 26-10-2010, 06:07 PM
foreigneRS
Testing the future
foreigneRS's Avatar
you are just talking about heat, not heak soak
Old 26-10-2010, 06:25 PM
Alg1k
Alg1k's Avatar
I was thinking the other day ( I know )
whilst looking at my new cooler which has the same core as rods
whilst he has painted his
I was wondering if it will make a difference in the efficency of the cooler
black tends to soak heat up with better efficency
so will it soak up radiated heat more than just leaving it
as it comes with no paint on at all
or will it dissapate heat better
or will there be no significant gains or losses ??
Old 26-10-2010, 07:50 PM
chaffe
chaffe's Avatar
what about the effects of an intercooler water spay to help conduct heat away from the cooler and the use of methanol injection?
Old 26-10-2010, 08:00 PM
phil_focus
phil_focus's Avatar
no mate, i was talking about both. if you place your filter in a hot area of the engine bay it will suffer from heat soak meaning the intercooler has got to disipate more heat which it cat do so up go your temps. even more important on an n/a, such as mine, car as theres no cooler.
Old 26-10-2010, 08:03 PM
Mark_
Mark_'s Avatar
may be a stupid question but ive always wanted to know,
whats more effective, a charge cooler of intercooler?
Old 26-10-2010, 08:46 PM
Alg1k
Alg1k's Avatar
I would say charge cooler if you have a big enough cooling rad
and decent head of water. And a decent size charge cooler
lot more plumbing and weight though
Old 26-10-2010, 08:49 PM
Staffi
Staffi's Avatar
Daz,
Slightly off Topic, how,s the build coming along bud??
Old 26-10-2010, 08:55 PM
Rsmat
300+
Rsmat's Avatar
thats the 3rd time you have asked mate and no one seems to be bothered.
Old 26-10-2010, 08:57 PM
Mark Shead
Mark Shead's Avatar
Not tested it to say it makes any diff but the paint needs to be thin, The other thought is to anadise it black this is also said to work.
Mark
Quick Reply: Intercoolers, and the effect they can have
