fiesta heater not getting hot
cossie fan (unluckerly)
Received 1,044 Likes
There is a valve that the 2 heater matrix pipes go through on the bulk head. This is what the fault could a. Its a common fault on the mk4/5 fiestas. I think the valve is about 45 quid from a local motor factor.
There is a valve that the 2 heater matrix pipes go through on the bulk head. This is what the fault could a. Its a common fault on the mk4/5 fiestas. I think the valve is about 45 quid from a local motor factor. If its not the valve it might be the actual dials.
na its not the valve as said it has no voltage to the plug when on hot if u plug the valve in the plunger moves about half way across but stays there what ever u do with the switch tryed a new one and it dose the same
Steve Escos
01-10-2015 06:57 AM
