what final torque needs for ARP studs and nuts
For YB head. 120Nm or 150Nm? head gasket Phuzion Cometic...
do not use the ford torque settings you will crack your block if you do
use the torque settings that came with the arp stud and nut kit as these are not stratch bolts so will require less tourque to do them up
i also did this years ago which were exactly written instructions off the arp ones i got
https://passionford.com/forum/techni...ions-here.html
but tbh id bin them and use normal head bolts
DavidK
27-09-2015 02:55 PM
