brake disk skimming......
Don't waste your money, it will come back and vibrate usually caused by DTV rather than warping that always gets blamed.
If still wanting to any decent machine shop with a lathe can do them, but make sure the are BACK SKIMMED, otherwise you have even less chance of a good job.
Location: Yarm (Teesside) previously from Fyvie (Aberdeenshire)
Try
Teesside Motor Factors, 15-19 Station Street,MIDDLESBROUGH TS1 1SR,
Tel: 01642 915442
I've used them in the past
Tel: 01642 915442
Turbocharging Technician
pitty you werent closer, i just skimmed my discs yesterday, machine is still set up not sure what tabetha means though by back skimmed?
I must say i agree with tabetha, warped or cooked discs will not recover from a skim, but slightly pitted or corroded ones will. (most fords sit all winter waiting on better weather so the discs can suffer lol)
Menace to society
Again, depends on why they need skimmed, if it is to make them flat again for new pads or to remove pitting then i say skim, if its because they are cooked then buy new.
I couldn't believe what I was seeing from geoff at high spec!!
lol, amature! be lucky to get it within a couple thou that way, even with soft jaws, not good enough. as long as the face of the disc is filed/emeryed smooth and the fixture is faced flat in the lathe (as shown) then they will always come out spot on, and it makes it a very quick and repeatable operation if you have several to do.
