how much bhp will siemens 86lb run?
friend wants 400 bhp but he was gonna run greys i told him not to so how much will 86lb siemens run ,hes on a t34.will it just be a simple chip/injector change? and at what boost pressure will he be able to run
Easy to work out, look up the formula I posted on here a while ago, with the website addy where you just input the cc/lbs and details and hit enter does it for you.
What's wrong with greys ?, perfectly good and able IF mapped correctly, as my engine proves 0.97% CO, 137PPM GREYS T3/34 ported head and 200,000 miles on the engine, or is that bad ?
the problem is tab is that were here in spain and there nobody to do a live map on greys so an off the shelf chip it is
The 55 lbers will be good for 400 hp no probs and will do 450 hp with the right pump and pressure..
If you need a greys chip for your t34 engine give us a shout we can sort that for you..
cheers danny
cheers danny
I rum Siemens 83lb or whatever and they are way to much for my 400bhp engine. I am running F88 management and the duty cycle is backed right off. I would go back to greys but the spray pattern is better on Siemens, I would have gone to 55lb but we mapped the engine on the 83lb and I have run out of time for an event im on this weekend. To get the AFR to anything nice on tickover they are just about injecting!!
James
James
