engine keeps running
Old Sep 22, 2010 | 05:33 PM
Ryan_3's Avatar
Ryan_3
Default engine keeps running
hi peeps, have a problem with my escort mk4! When I turn the engine off, it keeps running for like 5 seconds until it stops completely. It does it frequently not all the time. What can be the cause? runnign rich, carbon deposits, timing?
its a 1097cc valencia engine, uses unleaded petrol.
Old Sep 22, 2010 | 05:44 PM
St3V3_C's Avatar
St3V3_C
Does this have a solenoid on the carb to cut the fuel? Could be that?
Old Sep 22, 2010 | 05:56 PM
Ryan_3's Avatar
Ryan_3
dont know mate tbh!
Old Sep 22, 2010 | 05:58 PM
St3V3_C's Avatar
St3V3_C
Go look dumbass LOL
Old Sep 22, 2010 | 06:04 PM
martysmartie's Avatar
martysmartie
As you say most likely needs a de coke, carbon basically built up on the valves this causes hot spots which ignities the fuel after switch off hence the running on, has the timing been adjusted as well for the unleaded? Although unlikely to be causing this problem.
Martin
Old Sep 22, 2010 | 06:37 PM
Ryan_3's Avatar
Ryan_3
Originally Posted by St3V3_C
Go look dumbass LOL
dont have a garage and its fuckin raining outside
Martin
The engine was built from factory to run unleaded mate. Today I poured some redex in the carb and revved the engine, will see how it goes tomorrow now!
Old Sep 22, 2010 | 09:18 PM
atm's Avatar
atm
lmao, mine used to do this mate, it turned out it was a bad earth on my back lights! i think it used to cut out if i turned the heated rear screen on while it was doing it.. cant remember now.
Old Sep 23, 2010 | 06:37 AM
dojj's Avatar
dojj
Resident Wrestling Legend
More than likely to need the head off for a decoke as it's probably running a hot spot somewhere. Have you pulled the plugs out to see what they look like?
Old Sep 23, 2010 | 08:55 AM
R4N SS's Avatar
R4N SS
my rst did this after a mate properly ripped the fuck outta it and parked it up, pulled the keys out the ignition and the engine was still running
Old Sep 23, 2010 | 09:05 AM
charlie luciano's Avatar
charlie luciano
Sounds like the ignition timing to me
Luciano
Old Sep 23, 2010 | 11:16 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
I'd say carbon build-up aswell.
What octane fuel are you running it on?
Old Sep 23, 2010 | 12:51 PM
martysmartie
Oh of course I remember now the heads were revised in 1986 for unleaded, is that engine not quite rare in the MK4 Escort?
Martin
Old Sep 23, 2010 | 05:29 PM
Ryan_3's Avatar
Ryan_3
yes its quite rare ( and shit slow ) lol, cant even find a manual for it too!
dont know bout the octane, i just put normal unleaded.
Changed the plugs in march, will take a look at them. fortunetely today it didnt do it, maybe it was the carbon build up! will see the next few days.
Is a decoke expensive or difficult to make?
Old Sep 23, 2010 | 06:02 PM
user 7082039239
Try running it on 95 octane fuel. If that cures it, it definitely is coke build up.
Old Sep 23, 2010 | 06:21 PM
Ryan_3's Avatar
Ryan_3
we cant choose here in malta mate lol, its either lrp, unleaded, diesel or bio diesel lol!! shit I know
can the coke build up effect fuel consumption and performance as well?
Old Sep 23, 2010 | 06:28 PM
martysmartie
Unleaded is 95 octane at least in the UK it is can't image yours being different, SUL is 98.
Yes it certainly can.
Martin
Old Jan 8, 2011 | 12:33 PM
Ryan_3's Avatar
Ryan_3
well the diaphram was fucked so has been changed, the timin gi snow perfect, runs alot smoother now.BUT it keeps on doing this, mechanic now told me that it has alot of carbon build up and will need to remove the head!
Is the seafoam stuff any good? or do I basically take apart the whole engine with new rings etc.
Old Jan 8, 2011 | 03:51 PM
dojj's Avatar
dojj
the build up of carbon creates hot spots which leads to it running on/pinking/detonation whatever you want to call it
so you will need to open up the head/block and literally grind the carbon deposits off the face of the head, all around the valves and probably relap the valves into the head again
Old Jan 8, 2011 | 03:53 PM
Ryan_3's Avatar
Ryan_3
yeah, been told with grinding paste? but is it necessary to take the piston out etc too?
Old Jan 8, 2011 | 05:07 PM
martysmartie
You just need to scrape the carbon off with a flat headed screwdriver etc, you don't have to strip the engine, valve train etc.
Martin
Old Jan 8, 2011 | 10:30 PM
dojj's Avatar
dojj
pistons will clean up with just some normal wire wool
lapping the valves will require grinding paste and some elbow grease
its nice theraputic work
Old Jan 9, 2011 | 08:49 AM
david 100's Avatar
david 100
Its been many years since i heard that problem, back then it was caused by weak mixture causing hot spots in the combusting chamber
Old Jan 9, 2011 | 09:03 AM
RichieST's Avatar
RichieST
Could be worth getting another head and in slow time get some bigger valves etc in it and give it a port and polish! I bet a few extra gg's wouldn't go a miss eh!
Old Jan 9, 2011 | 04:24 PM
Ryan_3's Avatar
Ryan_3
yes mate, but to be fair its not that bad on fuel and it wont be economical then surely?
but what would be the cost of that? I know its a slow engine etc to start with, but I am going to keep this car standard and 'one day' rebuilt it.
Old Jan 9, 2011 | 04:27 PM
RichieST's Avatar
RichieST
Probably make it more economical to be honest! All you are doing is allowing the engine to breath easier by making it less restrictive.
Old Jan 9, 2011 | 04:34 PM
Ryan_3's Avatar
Ryan_3
ic mate that makes sense. do you know roughly the cost? cant see it being cheap!
Old Jan 9, 2011 | 04:45 PM
RichieST's Avatar
RichieST
I have no idea personally, can't see it being horrendous!
Old Jan 9, 2011 | 04:47 PM
Ryan_3's Avatar
Ryan_3
ok mate
big_Rad
Sep 15, 2017 09:36 AM
Red_bull
Aug 25, 2015 06:27 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
