diff gurus have a look and explain please
Old Sep 20, 2010 | 04:11 PM
james kiely's Avatar
james kiely
Default diff gurus have a look and explain please
could you translate what the writing on the diff means please and cna you tell if its quaiffe or not please
Old Sep 20, 2010 | 04:41 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
its not a quaife and its not a cosworth crown wheel and pinion as they are a 3.64 and not a 3.9
Old Sep 20, 2010 | 04:46 PM
james kiely
you can get 3.9s james
Old Sep 20, 2010 | 04:58 PM
ajamesc's Avatar
ajamesc
yeah u can get 3.9s i carnt make out if its a 3.92 if so they come in 1.6 ovh / 1.8 ohc / 2.0 ohc efi / going by my list!
Old Sep 20, 2010 | 05:00 PM
james kiely
it says 3.92 james
Old Sep 20, 2010 | 05:46 PM
james kiely
upski
Old Sep 20, 2010 | 06:53 PM
james kiely
the writing says
ok....4119..........3.92...........0/90
Old Sep 20, 2010 | 07:07 PM
ajamesc's Avatar
ajamesc
the writing says
No idea on the 4110 or the 0/90 the only one that matters too u is the 3.92 as thats the ratio! and it wont make that much difference any way so just use it!
Old Sep 20, 2010 | 07:22 PM
james kiely
cheers ajamesc ,thanks for your input ,the thing is its being offered to me as a quaiffe diff
the 90 thing i have been told is it is locked at 90%
Old Sep 20, 2010 | 08:16 PM
ajamesc's Avatar
ajamesc
well it isent a quaife tell them
Old Sep 20, 2010 | 10:40 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its not a quaiffe ATB diff, as if it was it wouldnt have that pin in the middle of it, they have a totally different gear setup to that.
Old Sep 20, 2010 | 10:41 PM
Chip's Avatar
Chip
PS
Looks like it says ".090" to me, which is probably saying its got 90 thou of clearance, but that is only a guess.
Old Sep 21, 2010 | 07:55 AM
james kiely
thanks ajamesc ,
thanks chip ,much appreciated
so i take it ,it looks just like a standard inch71/2 diff with a 3.92 thats been tightened up,
Old Sep 21, 2010 | 08:11 AM
Chip's Avatar
Chip
yes it all looks standard to me, although im not a diff expert, try pm'ing steveboyslim for a definitive answer, as he deals in a lot of diffs, both standard and modified ones like quaiffe etc.
Thats who I always go to for diff parts/advice.
Old Sep 21, 2010 | 08:16 AM
silky16v's Avatar
silky16v
Get on That!
For a second there James i had thought you blown Diff up in the Moonstone Saph
Old Sep 21, 2010 | 12:24 PM
bookwyse's Avatar
bookwyse
Its just a standard diff and the writing itself only tells you it's a 3.9 ratio. They markings have been put on by whoever reconned the diff by the looks of it.
Jeff
Old Sep 21, 2010 | 05:42 PM
james kiely
cheers chip
no chance matt its parked up for the winter
Jeff
hi jeff ,thanks for your input ,so its just standard then
Old Sep 26, 2010 | 01:21 PM
dakunia's Avatar
dakunia
I'm not sure is it 7,5 or smaller 7" diff - it can be Sapphire 4x4 2.0 DOHC 7" diff, which was fitted to this cars. Was exactly 3,92 stamped on it, not 3,90 or 3,91.
You should measure diff housing - is it 7 or 7,5"...
regards
maciek
Old Sep 26, 2010 | 01:25 PM
dojj's Avatar
dojj
Resident Wrestling Legend
mark the input and output flanges and tunr the input and measure the rotation so find the ratio
simples
if it's a 2.0 dohc 4x4 rear diff it will be an lsd and 7"
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
RSmark84
Sep 13, 2015 01:29 PM
hopper350
Sep 4, 2015 12:53 AM
