fiesta turbo
Old 18-09-2010 | 01:24 PM
bennzy's Avatar
bennzy
Default fiesta turbo
hi im in need of 2 fiesta turbo front hubs that i cant find for love nor money ive been offered 2 fiesta si hubs ansd was just wondering what else id need to change over as heard there 2 different types and help greatly welcome
many thanks
Old 18-09-2010 | 05:18 PM
1223456's Avatar
1223456
I have 2, come and get em, will cost you a bottle of coke zero
MUST BE COLD THOUGH
Old 19-09-2010 | 02:52 PM
bennzy's Avatar
bennzy
lol lol bit far mate thanks for offer tho
Old 19-09-2010 | 03:24 PM
vaughant's Avatar
vaughant
many thanks
The actual hub never changed,the only difference was the very early fiestas(f&g reg) used a much weaker design,the turbo simply used a stronger hub,which was then adopted to all fiesta models from about j reg and on,your si hubs will certainly be the same.
I know,because the factory I worked in made them on the line next to mr for about 20 years!!!!
Old 19-09-2010 | 03:57 PM
crazycage's Avatar
crazycage
wrong !! the fiesta si hub wont fit , the hole the shock sits in is bigger and the splins on the shafts too.
Old 19-09-2010 | 04:10 PM
vaughant's Avatar
vaughant
Wrong?they're the same parts,I used to work in the ford plant that produced them!!you may well be right regarding the shocker but that's called a knuckle,not a hub,we used to make them as well,but for the escort!!!
I also put a whole leg onto an xr2i before of an si but I didn't seperate anything.we never changed the broaches to suit an si,and knowing ford engineers they most certainly wouldn't have changed an entire production line to suit one model that ran for 2 years!!!
Old 19-09-2010 | 04:20 PM
crazycage's Avatar
crazycage
mate anyone that know anything about fiesta's knows there is a difference between the mk3 and mk3.5 hubs ! you can bang on about working in the factory all you like fact is they are different and dont fit .
a lot of people change over to the mk3.5 stuff because of the better wheel bearing but you need to change the shaft and pop a 1mm sleeve in the hub so the shock will fit.
Old 19-09-2010 | 04:21 PM
shalon's Avatar
shalon
im sure the mk3.5 shocks are a bigger diameter at the bottom than a mk3 a rs or xr or normal 1 would fit
Old 19-09-2010 | 06:00 PM
JayCC's Avatar
JayCC
UI know that the XR2i 16v had more splines on the hub, as I had to order one when I broke a CV joint. (everything on that corner was mangled)
Luckily the bloke at the breakers yard I spoke to was really helpful and told me to check how many splines my car had. From memory (6 years or more ) it was 24 or 26 splines..?
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: fiesta turbo
