Transit help again please!!!!
Old Sep 13, 2010 | 09:49 AM
Ima Racing's Avatar
Ima Racing
Default Transit help again please!!!!
2.4TDCI TRANSIT MOTORHOME 2004 WITH 15000MILES!
Diesel centre listened and said advance solenoid on pump, van ruuning very advanced and very loud underpowered.
Now the symptoms started as i slight louder noise occasionally no loss of power...then all normal for quite a few miles.....then very loud under powered.....the last night it ran back as normal spot on perfect for the evening.....started it up today and fine revved it dropped back to tickover then...knock knock knock back to running shit...
Now is this a normal thing with a pump issue? I would have thought either the pump is fucked or not why is it occassionally running perfect....the diesel centre didnt bother to put on diagnostic machine as they were certain of noise....but 15000 miles, i know its 6 years old but still?
Any suggestions? (on tick over from cold very loud and stalls and gets glow plug light flashing which should store a fault code? I told them this but still didnt hook up) Diesel pump?
Old Sep 13, 2010 | 10:43 AM
Tank Mike's Avatar
Tank Mike
Sounds bang on like the pump to me. Transits always do this when the pumps are on there way out!
Old Sep 13, 2010 | 10:47 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Not uncommon for people to leave the engines running for long periods when parked up in a motorhome, so the milage isnt always a great indication of the number of hours use the pump has had.
Old Sep 13, 2010 | 12:17 PM
Doug's Avatar
Doug
Phil As common as dog shit on your trainer !!
Ring your local ford dealer ask them for an injection timming solinoide approx Ł85 and a couple of hours to fit .
Regards Doug.
Old Sep 13, 2010 | 01:08 PM
saph4be's Avatar
saph4be
so youy take it to specialist and ignore there advice and ask on the internet
and i sure you had a thread askin the same the other day
ffs sake stick a solenoid in it and be done with it!
Old Sep 13, 2010 | 02:13 PM
Ima Racing's Avatar
Ima Racing
The Ford main dealer wont fit a soleniod as they say its about 300 quid and best to fit a new pump to be safe
Old Sep 13, 2010 | 02:59 PM
Ryan_3's Avatar
Ryan_3
then fit a new pump
Old Sep 13, 2010 | 03:48 PM
Doug's Avatar
Doug
Fit it urself piece of piss job .
Regards Doug
RichieST's Avatar
RichieST
I'll agree with that, some of our wagons at work are started at 7 30am and aren't turned off until 5pm, some of them must do no more than 10 miles a day. The transit used in my hangar is on an 05 plate, has about 9000 miles on the clock!
Old Sep 13, 2010 | 09:59 PM
DazC's Avatar
DazC
TDCIs don't have an injector pump to have an advance solenoid in as they are common rail. TDDIs were common for it though. Easy fix unless the pump has started to go fucked as then the solenoid sometimes won't come out when it does.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
Adam-M
Aug 27, 2015 08:55 AM
SteveyDee
Aug 25, 2015 07:48 PM
