Stuck in ireland please help.....
hey guys im new here and have a pretty serious problem!
Here it goes.
I booked a ticket to get the ferry to ireland tuesday morning on the 02.40 sailing. i have a 2005 ford focus 1.8 tdci so i didnt think that journey would be any problem to a car like that, (i was wrong) i drove the car on the motorway at about 75 mph on cruise controll for about 3 hours, no signs of any problems, temp needle in the correct place, plenty of diesel and so-on. the car just cruised like i would expect it to..
anyway about 100 miles from the ferry i needed a toilet break so i slowed down to pull in and suddenly the car cut out and all breaks and steering got very very heavy.. but i managed to pull in to a lay by. it would not start for about 10 minutes but it eventually did.. it proceeded to do this twice more when i arrived in ireland.. i did get a message on the dash saying engine systems fault but when the engine does eventually restart that message dissapears.. leading up to this fault occuring i noticed that on the odd occasion when in any gear and between 1300-2000 revs whilst slowly accelerating the car will hit a flat spot where it looses power for a split second and then regains acceleration. the only way i can explain it is it feels like someone has tried to pull the car backwards and let go.. both these problems happen when the engine is hot or cold.. please help guys or im stuck in ireland and garages here charge an arm and a leg..
Here it goes.
Could well be an injector or pump problem. They are prone to occuring when the pressure drops and then builds up again.
Whereabouts in Ireland are you as I am over here at present in Waterford and have a laptop with me. I can use the obd lead from a mate of mine here to try and see if we can help.
Jeff
Jeff
im in co clare.... i just took the fuel filter out and its a paper one. what i noticed is that the small rubber ring on the filter head is out of shape!! could this be the problem?? its not the big ring that seals the whole unit but the little one inside.
If the O ring on the filter is out shape then there is a strong possibility that there is air in the system which could cause the symptoms mentioned.
Try putting a new o ring on it and seeing if that works.
Jeff
Jeff
ok i will get a new fuel and air filter!! i just emptied out the fuel filter contents and have found two ir three minut particles of metal.. these are very very tiny and i can just barely make them out.. thats not normal is it???
Particles of metal in the fuel filter is a very very bad sign. Any metal particles can spell the end of the injector pump, fuel rail and injectors. The issue with the common rail is the high pressure involved and any foreign particles can cause failure.
Fords recommend that if any traces of foreign eg metal particles that the pump, rail and injectors are replaced at huge costs.
if they were in the injectors wouldnt the car be running lumpy all the time??? i will bung in a new filter today and try to reconstruct the failure and see what happens.. if i had to change those bits how expensive is it??
i heard that the pump in the tank can cause these problems!! how easy is it to remove this one for inspection and does anyone know which side of the filter the big o-ring goes?? cap side or underneath side??
have just changed the fuel filter and the car is running fine but then again it was an intermittant fault so i will have to see if it happens again on the way back to uk... i need to know the name of the silver unit that sits in top of the inlet manifold as it makes three rapid clicks after turning off the engine!!! it has a plug in the end with the black piece bolted on and the rubber hose comes out the other end!! any ideas??
dunno if i would get my money back lol.... anyway i wanna fix it cos its a lovely car otherwise, all the way to ireland in comfort except for the breakdowns...
Took a few listings, had a few people offering me like £80. Some guy wanted me to send it to Brunei (maybe it was the Sultan for one of his cars ) then these lads from Wales phoned me up and offered £200.
Be patent and you will find your buyer. Now I just have a load of VAG diesel turbos to get rid of!
cleaned the egr valve as best i could with the thing still attached to the car, used petrol in a spray bottle and a tooth brush, got alot of crud out, cleaning that and changing the fuel filter have made a big difference to the running of the car and my mpc has increased by 12 mpg so its looking good plus it seems to have cured a slight vibration at certain points along the rev range and my flat spots too now just to see if the original fault re occurs on the way back to england on tuesday,,, fingers crossed
muz
30-09-2015 08:29 AM
