Hi pressure oil pump Question ............
Hi will be building my bottom end up shortley on my Esc Cos and I need to know if it is ok to use a high pressure oil pump with the standard spray bar?
do you have to modify the 4 spray jets ?
Dave
PS any tips on building it up will be appreciated
Dave
just put a h/p pump on mine no need for any mods but fitted a oil cooler to keep the pressure down 2.1 bar idle and 5 bar at 4000rpm
I have allready got one but the guy said that I would have to remove a alloy bung from the pump if I want to use it with the standard spray bar !
do you know what he means ?
Dave.
Dave.
lets get this corect
its not a alloy bung its a steel one
do not remove the bung theres a spring and cap behind it that regulates your oil presure
the only diffance between a hp pump and normal is the Ł11 coswrth spring and cap
big_Rad
15-09-2017 09:36 AM
mrmann
20-08-2015 11:24 PM
