mondeo st200
mondeo st200
hello to every one befor i start i dont know if i have put this in the right place so if i havent please put me right
right could any one of you tell me where i can find my obd2 plug on my mondeo st200 just got a new reader but cant find plug for it any help would be great
not runing good at all miss fireing little lumpy and i went out in it the othere day on way to work and it ran like it was runing out of fuel so i put more in and still the same then just stalled would not start after that so got it home left it for a bit went out and started it seem ok then take it for a run same thing i got to my brothers then atfter about fouty min went started it come home it was ok and been ok since so ben two day all ok for now so got a reader and ill start from there this the reader i got not sure if any good though
U581 Diagnostic Fault Code Reader Scanner CAN OBD2 EOBD
got leads on order so going to try them i got my code reader plug it was fix on the bottom under the steering wheel so thanks for helping me find it and all that was on there was my egr valve said it was low dont know what that is but will have to find out
EGR Valve is the Exhaust Gas Recircultation Valve, its near the top of the UIM near the bulk head. blank it off with an EGR blanking plate, you dont need it, all it does is block up the UIM, LIM with shite, its only there to keep the emmisions down and keep the eco warriors happy. its adviseable to remove the UIM, LIM, and clean them out before you do it, clean the secondaries out aswel while your on, will make the car run better as ill guarantee they have never been cleaned out, and will be full of shite. cleaned mine out, the car was like night and day, runs a lot better now.
yes mate, it will still sail through the mot. the secondaires open at around 3.5K revs. when you have full throttle, and around 3.5K revs you feel that big pick up in power, that is the secondaires opening. the engine is a big old thing to look at, and can be intimedating at first, it fills the engine bay, and there are lots of pipes and hoses, but once you get to know there ins and outs, there actually, pretty simple old things.
yeah you ant kidding when you say it fills the eng bay but i will give that a go going to take it to bits at the week end i have all so booked a Rolling Road Session as well got that on the 14th september so i hope that will give me an idea of whats going on with the eng and get what ever needs sorting out sorted i hope and its something i have wanted to do as i have never seen one for reall so should be fun as well it ant a bad car for a ford lol and i have had some bad ones
wowk
30-03-2021 07:49 PM
