carpenter/builder types
Old Aug 26, 2010 | 06:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default carpenter/builder types
i'm after them self tapping type screws that are black, and have a bit more of a point on them
i'm sure you know which ones i mean, they've got a different sort of cross slot as well at the top, they are tighter than normal wood screws
are they plasterboard screws?
need to go and get 1 or 2 tomorrow to replace a few that i've "lost" when i 've been taking things apart so need to get the right ones so they'll look right
but can't remember what they'd be called and google is being a twat about showing pictures
Old Aug 26, 2010 | 06:02 PM
cpaul4's Avatar
cpaul4
Plasterboard screws would do the trick .
Chris
Old Aug 26, 2010 | 06:04 PM
Shings's Avatar
Shings
Screw fix!!!!
All day long
Old Aug 26, 2010 | 06:05 PM
dingla rs's Avatar
dingla rs
plaster board screws answerd ur own question
Old Aug 26, 2010 | 06:11 PM
dojj's Avatar
dojj
one more thing, when putting in flooring, is there a thing to stop bugs and flies and shit like that coming through?
and mice and rats and shit from chewing through?
looking at doing it once so if there is something specifically for it rather than having to lay down loads of metal plates
Old Aug 26, 2010 | 06:13 PM
dojj's Avatar
dojj
http://www.toolstation.com/shop/Scre.../sd3165/p66702
these ones look like what i've got, we've got wooden battons in the kitchen and the units have been fixed to them and to each other to stop them falling over, for want of a better word, and i've moved stuff about as we had to do some plastering behind and now we've obviously lost the screws
but i only need about 5 at the most, so don't really want to shell out on thousands
Old Aug 26, 2010 | 06:19 PM
cpaul4's Avatar
cpaul4
The plasterboard screws are pence so only really come in bulk. Best off going to wicks or somewhere and seeing if you can buy a few. You will proberally pay the same amount though.
Not sure what you mean about the flooring? Is this is a loft? over a screeded floor?
Chris
Old Aug 26, 2010 | 06:30 PM
dojj's Avatar
dojj
we've got an old house and underneath the floorboards there is about a 2 foot gap where the joists span the floor, then the floorboards go in etc and we've had instnaces of mice getting in through the air bricks and chewing up the cables that go under the floor
only really find out it's a mouse when the leccy pops and then we find a fried rodent but we also had a few brave buggers a few years ago who found a way through where the pipes come through the floor around the floorboards where they've threaded the electricity to the meter and run the gas and water pipes etc so i just want something that i can put down to keep everything out before i stick some of the spare laminate flooring down around the place to tidy it up under the stairs
Old Aug 26, 2010 | 07:02 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
wire wool is about the only thing that will stop them, they wont eat through it.
Steve
Old Aug 26, 2010 | 07:05 PM
rubinsbin's Avatar
rubinsbin
Dry wall screws----------
Old Aug 26, 2010 | 08:15 PM
project rs's Avatar
project rs
it's not drywall screw he's after he's on about chipboard screws that hold the kitchen cabinets together with a course thread you get them when you by a a mfi unit you all know the screw
Old Aug 26, 2010 | 09:09 PM
dojj's Avatar
dojj
wire wool
chipboard screws
thank you
Old Aug 30, 2010 | 02:38 PM
dojj's Avatar
dojj
ok, should have taken pics but it was dark and dingy and here's no flash on the iphone so:
what we did was rip up ALL the floorboards that were close to where we needed to secure
we then built up pillars of bricks to go around all the pipework and electrics, but we lagged them with that pipe lagging stuff you put on water pipes first, and then wrapped a few sheets of plastic around them, before filling the gaps up with wire wool
then we put the floorboards down back were they were
then we put another set of tongue and groove boards on top of these boards
and then another lot on top of those to make the level back up to the correct height to cover all the pipes that were all over the place
the only major problem was the stop cock for the gas, which is actually at the same level as the original floor, so we left that alone for the time being
but other than that, it's actually turned out to be a good days work
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Si B
Sep 12, 2015 06:49 AM
