TV's Mounted On The Wall
#42
@ Lozi
Plasterboard on block or just a stud/partition wall?
If the former, use these: http://www.directbuildingproducts.co...s3.php?id=1525 - 12mm drill bit, jobs a good 'un
If the latter, you will have a few options:
- If it's a studwork wall - many brackets can reach between studs - two big screws into the studs will suffice. Other brackets have the option of using a 'spreader', which screws to the studs and bolts to the original bracket.
- If it's one of those 'egg box' walls, you'll have to either:
- a) cut it open, put a horizontal stud in where you want the tv to go, re-board, skim, etc; or
- b) use a pole mount - if there's a loft above the mount can go in the loft and you just have the pole sticking through, looks neat. if no loft then you'd have to have the mount showing, fixings into the joists.
HTH
Chris
HTH
Chris
#44
@ Lozi
HTH
Chris
HTH
Chris
The wall i wanted to use is just platerboard no studding and thats more work than i would have liked to do so i guess ill have to use one of the outter walls as they are plaster on block.
Thanks for the reply
#45
#46
Cool One thing I would say is, going by the pic which may not be accurate, your contrast setting is too high - you want it set so that the brightest white is just distinguishable from a slightly less bright white. If you do a google search for 'pluge pattern', save one to USB and show it on the screen that'll help you set them correctly
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
