Lambda Sensor
Old Jan 22, 2005 | 08:57 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Default Lambda Sensor
Right i have seen the Ford mag this month,
I have been told that if i fitted a lambda to my Hplate 4x4 cossie and ran a live ect to an air fuel gauge uit will read, and that there is no need to go via the ECU ???
Is this right ?
Old Jan 23, 2005 | 11:40 AM
GARETH T's Avatar
GARETH T
not sure what your on about?
Old Jan 23, 2005 | 11:42 AM
ballin's Avatar
ballin
neither do i really, but yea if you install a lambda sensor in ya downpipe you can run an AFR gauge straight from it.
Old Jan 23, 2005 | 11:48 AM
DazC's Avatar
DazC
The article in the mag has nothing to do with a guage.
To have an accurate guage you need an expensive wide band lambda sensor otherwise you will get nothing more than a glorified christmas tree on your dash...
Old Jan 23, 2005 | 02:15 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: Lambda Sensor
Is this right ?
Im unsure what your talking about too
I hope a pro didnt tell you that the article i did was about an AFR gauge though, i really do
Old Jan 23, 2005 | 05:09 PM
GARETH T's Avatar
GARETH T
bttt for Leggetts 4x4 Cossie, to explain what he needs
Old Jan 23, 2005 | 06:45 PM
Leggetts 4x4 Cossie
I have a Escort Cossie Turbo in a Hplate 4x4 pre lambda,
I have got a second hand lambda, and want to wire it up to an air/fuel gauge.
From reading the article Stu wrote, i thought that i would need to have the Lambda run through the ECU for it to work,
Is that the case ?
Or can i run the Lambda to the air fuel gauge with out going via the ECU,
Sorry for any confusion, im not the best at trying to explain what im looking for.
Old Jan 23, 2005 | 06:49 PM
GARETH T's Avatar
GARETH T
yes you can do that
do you do many miles in your car? if so closed loop fuel control is worth thinking about,, im sure it will pay for itself very fast
Old Jan 23, 2005 | 07:13 PM
simonc's Avatar
simonc
Status: Offline
Posted: Sun Jan 23, 2005 8:45 pm Post subject:
An H plate escort cossie, thats a new one on me !
Simon.
Old Jan 23, 2005 | 07:20 PM
GARETH T's Avatar
GARETH T
Old Jan 24, 2005 | 03:58 PM
Leggetts 4x4 Cossie
Lost me ! ! ! !
Old Jan 24, 2005 | 04:10 PM
ballin's Avatar
ballin
this makes my head hurt
you mean saph cossie mate??
and as i said ya you can run directly from probe > gauge
Old Jan 24, 2005 | 04:37 PM
flashpoint's Avatar
flashpoint
As Rich says, just run the lambda straight to the gauge, stay away from the ecu.
Steve
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
