Had a crap Ford Fair!!
#41
Gutted for you, hope you and your brother are OK, don't give up on the car, its easily saveable.
#44
Thanks for all your kind words guys!
Yeah the pin was in on the engine bay system, as said i get worried about somebody pullin the handle buy mistake!!
Found the real cause, I run a 4x4 rail, the head of the front mounting bolt has sheered off, letting the rail move out under pressure, causing the O ring to blow out!!
I steam cleaned the engine bay down today, there are lots of melted bits. Gonna get the motor out next, then go from there!!
#45
The main thing is that you are ok.
I was in the same session and when I saw the flames I felt really sorry for you.
Also so smoke pouring from a mk3 fiesta just back from you as well.
#50
OMG, glad all ok tho, sorry about the burns
Good luck rebuilding it,
#51
[QUOTE=markk;5038445]real sorry for ya dude, but you should have known better about the pin.
electric kit is the way to go pal - switch it off when people around, arm it when in use.
im sure it looks a lot worse than it is.[/QUOT
Yes maybe in heinsight, I have just refitted a manual system, I had an electric one in early this year, Had a flat battery before a stage start, trying to get car goin and set it off! The scroots dont like them either.
As for the foam, better off peeing on it, only got this out cos they had powder!!
#52
sad to see we drove through the smoke on the second & last lap of the session
as we came round the corner i thought all the smoke was from the red fiesta then spoted the sierra with the fire truck behind it
hope your both ok cars can be fixed and im sure once the fire extinguisher is brushed off it wont look so bad
#53
to EVERYONE CONTEMPLATING TRACK DAYS!!!on board lifelines and proper hand helds not those tiny things from halfords,
IVE SEEN PEOPLE BUY THE ONES NO BIGGER THAN A DEODERANT CANS BECAUSE THE ORGANISERS SAY YOU NEED A FIRE EXTINGUISHER!!!! AND THEY LET THEM ON THE F-G TRACKS!!-ITS YOUR LIFE NOT THERES-
PROPER SCRUTTENEERING AND MSA-FIA ONBOARD EQUIPMENT-MINIMUM
PROPER OVERALLS!! UP TO DATE-NOMEX ETC ETC GOOD IDEA???? PROPER HELMETS NOT YOUR MATE MOTORBIKE ONE!!=RIGHT THATS IT HAD MY SAY
you was lucky,very lucky thank god i t could have been much worse anyone remember nicky lauder),
---keep safe -- the cars secondary!!!!
#57
Im in the focus right in front of you.
#58
Chin Up Rich , hopefully it wont cost you to much to get it straight again ....Atleast your both in one piece m8 it could have been alot worse by the looks of things ....
The Underdog
29
07-09-2015 09:49 PM
Versus_Creations
24
05-08-2015 09:32 PM
