electric window problem saph.
Old Jul 27, 2010 | 09:33 AM
smartrs's Avatar
smartrs
Default electric window problem saph.
3 of my electric windows work and the passenger rear does not , now i know this is not the end of the world but i'm changing door cards and thought i'd take a look while the card is off , i've tested the motor and that works fine with the window going up and down , now am i right in thinking that each window will have its own relay ? if so where are they hidden ? or may it be somethng else ?
Old Jul 27, 2010 | 09:53 AM
t4 and greys's Avatar
t4 and greys
cosworth gimp
mine done this and the rear switch in the back of centr console was goosed
Old Jul 27, 2010 | 10:04 AM
smartrs's Avatar
smartrs
did yours work off the front button ?
Old Jul 27, 2010 | 10:11 AM
Mike Kerbey's Avatar
Mike Kerbey
Take the switches apart and give them a clean up. They will work perfect after.
Plus to check the switch, swap the two rear ones over and see if the fault follows.
Old Jul 27, 2010 | 10:51 AM
RS500/364's Avatar
RS500/364
As said clean the switch contacts as after time they arc blacken so don't make contact!
Old Jul 27, 2010 | 11:14 AM
smartrs's Avatar
smartrs
ive swapped the swiches over and still the same the one that opened still opens and the one that did ot still wont work , god these cars get to you small niggles but i still feel the erge to try and fix it .
Old Jul 27, 2010 | 11:40 AM
Mike Kerbey
It must be the front swich that is faulty then. Clean the front and back switches up and they will work.
Old Jul 27, 2010 | 11:54 AM
smartrs's Avatar
smartrs
i'll try that soon its tipping it down with rain here now and as muggy as anything so will give it ago later thanks for the advice
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
