who knows there beans on here????
ok i am going to pick your brains here,it may be a simple fix but i dont know much about theese things ,but that is why i am asking you guys so here goes..... i have a erst fitted with a collins dump valve. when running the car and it gets upto temp it then stops ticking over.the only way to get it ticking over again is to block off the pipe from the manifold to the dump valve. does this mean that the dump valve is bo***cksed??? or is it something else???
thanks in advance chris
thanks saph i will if i have more probs. i am going to bung the large samco pipe with an offcut of a broom handle and see if this fixes it untill i get a proper bung. where in mansfield you at mate???
chris
chris
JUst replace the samco with a proper hose and be done.
Fuck the air leak valve off and if you really must then shout PTSHHH every time you change gear.
defo will remove as every body is saying this so will do , thanks guys also does anyone know what diameter is on a collins dump valve as on ebay the dump bungs keep coming up 19mm 25mm 28mm 30mm etc ??? any guesses????
wheelwizardrefurbs
22-09-2015 05:45 PM
