Saphhire boost?
Saphhire boost?
just was wondering what is the maximum boost i can run on a standard green top all standard and standard L8 with out it being lean. it runs a standard 10psi at the moment? help would be great.
So many variables, but should be good for stage 1 and 3, so about 14 and 22psi, but needs checking before meltdown as in afr check under load, but this of course means a new chip/actuator.
With std chip I wouldn't run anymore than std, not worth the risk, stage 1 makes a huge difference most notably to torque, and improves mpg when not booting it, and can be as little as £200
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
