in need of a live mapping session!! wheres good??
#41
titan is the new name for silkolene pro s 10/50
get it off oilman off here (opie oils), you get a discount for being a PF member i think
http://www.opieoils.co.uk/p-68898-fu...ngine-oil.aspx
#43
cheers danny
#45
I spoke to mark shead about it at combe and he recomended this other oil so im going to give it a go...
cheers danny
#47
edit: found it from another thread
Im probably the only one on here that has his oil chemically checked after a Topspeed run. Castrol RS was out of Spec after just one run down Brunters & had 8% fuel blowpass. I use Silkolene 5/40 which has proved to be the best for my application, showing less than 2% fuel blowpass & maintaining its Spec after repeated runs.
#48
hello again, im a bit concerned that my k&n air cone wont let enough air flow in for the stage 4 set up ive got??? do you think this will restrict power output??? cheers, adam.
#54
#55
Passionford Thread Killer
Hi adam , have been told there's a white one round our way and here you are .
Im in wimborne btw.
Alot of people use/rate silkoline 10w 50 - http://randbmotorsport.co.uk/shop/Pa...ID=7&offset=10
Im in wimborne btw.
#60
Im in wimborne btw.
Im in wimborne btw.
#61
I know antoher fella in poole with a red one and there was an imperial small turbo in corfe mullen but it got wrote off .
Think i fitted a carpet for your mate, just before ford fair last year this guy said about a white one local that he'd be goin up in.
Get yourself over on escortrscosworth.com somstime.
#62
im on that site already!!! joined the other day!! see you around mate. adam
#63
I was close then????luke said it peaked just over 2 bar and the boost fell of as usual to 1.6 bar so explains the good torque and if the boost held on a bit longer would of done 400hp so all in all a good engine!!!
Nice one adam bet it flies???
cheers danny
cheers danny
#69
cheers danny
cheers danny
#72
yes you were very close almost spot on id say!!! yes it does go well, much smoother than before!! what would make the boost hold longer then??? not that im bothered but just wandered?? oh and luke said my plug gaps mite be too big at 22 thou so if i decrease the gap would it affect the map you just done??
Glad your happy mate...
As for the boost its natural for it to drop of but can be down to a few things but as luke says its bang on as it is and didnt want to waste any of your money just to get the car to hold boost a tad longer as it was sweet!!!
Also means the turbo will last longer at a bit less boost...
cheers danny
#73
If the car doesnt splutter as it comes on boost then dont touch the plug gaps...no need..
cheers danny
cheers danny
#74
Excellent figures from EP you must be well chuffed! How much did it cost you in the end?
#75
hello, im just in the middle of converting mine to rwd so yeh im up for a bit of a play when mines done!!! should be over 400 bhp when its done!! the mapping session cost £160 well worth it .
#77
i am a little bit confused cos someone told me that i need a 2wd gearbox, 2wd 7.5" diff, shortend prop, and a 2wd rear end!!! but i was told i can leave the 4x4 sump on it????? or do i have to change it??? im a bmw mechanic by trade so i will be doing it myself!! any tips??
#79
I believe you can leave the 4x4 sump but you need to grind a part of it to clear the bigger 2wd starter motor. Mine has a 2wd sump so no problems!
If you would like to meet up and have a look over mine and talk it through just let me know. I did my conversion myself in a week; I also changed the engine and converted from eec4 to weber management at the same time!
#80
