What oil do you use in your YB ?
09-04-2009 | 10:32 AM
Basically as title, its not a fresh engine, its probably done about 30k from being built and those are all hard miles.
Would you always use a fully synthetic oil regardless of mileage ? if so which one ?
I've always got on with Shell Helix semi synthetic in my own engines (non YB) I see Halfrauds are doing Mobil One cheap at the moment too !
Thoughts and suggestions please
09-04-2009 | 10:37 AM
I just use a semi 10/40
Steve
09-04-2009 | 10:38 AM
i use mobil 1 motorsport 15w/50
09-04-2009 | 10:44 AM
only ever used Silkolene to be honest.
09-04-2009 | 10:45 AM
*** Sierra RS Custard ***
Got some 300V motul for the new engine im building, current one just gets any old 10/40 - 15/50 semi or fully synth depending on what is lieing about.
On a YB I cared about, I would recomed either the motul or if you want to save a few quid then silkolene.
09-04-2009 | 10:47 AM
09-04-2009 | 10:56 AM
Mobil 1 Motorsport 15/50
Is recommended by several of the Cosworth tuning companies such as Collins/GGR etc. So good enough for me.
09-04-2009 | 11:11 AM
I use mobil 1 motorsport on mine
09-04-2009 | 11:21 AM
Mobi 1 for me, 15W50, only cos I've run out of SUNOCO Racing oil
09-04-2009 | 12:11 PM
09-04-2009 | 12:23 PM
Castrol 10/60 Extra Virgine, will give the Mobil 15/50 a try once ive changed the oilpump (it was quite a bit lower than the Castrol)
09-04-2009 | 12:33 PM
09-04-2009 | 12:44 PM
Mobile one 15/50 for mine recommended by norris motorsport
09-04-2009 | 12:45 PM
09-04-2009 | 01:16 PM
Quote:
Originally Posted by
ybturbo
I use Motul 300V 15W-50
Even the cans are sexy too if you get the 2 litre metal ones, lol
09-04-2009 | 01:18 PM
mobil 1 15/50 too, its sitting in the garage still thou awaiting me to finish the engine
09-04-2009 | 01:24 PM
I tried Millers 10-50w last time round and the engine seems to like it
09-04-2009 | 01:25 PM
mobil 1 15/50 here aswell
09-04-2009 | 01:57 PM
The red stuff - Silkolene PRO S 10w 50 - change every 2.5/3k
Used to use semi synth Castrol RS10W 60 previously
09-04-2009 | 03:23 PM
shit i think ave seen a ghost!!!!!
09-04-2009 | 03:27 PM
Mike1
thats what i used to use in mine as well, most people i spoke to recommended it
09-04-2009 | 04:06 PM
09-04-2009 | 04:10 PM
i used silkloene pro s 10/50 in mine
heard good things about millers too, but have had no experience of it
09-04-2009 | 05:30 PM
silkolene pro s 10/50 in mine. Seems good.
09-04-2009 | 05:31 PM
09-04-2009 | 05:32 PM
Captain500rs
09-04-2009 | 06:02 PM
bud-weis
+1
09-04-2009 | 06:41 PM
Right so Silkolene seems to be coming out on top of the most used Oil.
Who's best to get it from ? Opie Oils ?
09-04-2009 | 07:36 PM
JonnyBravo
Always get mine from Opie mate
09-04-2009 | 10:38 PM
09-04-2009 | 11:48 PM
JonnyBravo
Opie sell it, and for a couple of quid a litre more, they also sell the Motul 300V
10-04-2009 | 08:08 AM
Mike1
why do you change it so frequently?
10-04-2009 | 08:13 AM
Mike1
Surely there is no need to change it so often?
10-04-2009 | 08:22 AM
daviddunlop83
There is every need to change it at 3k, im probably the only one on here that has his oil chemically checked after a Topspeed run. Castrol RS was out of Spec after just
one run down Brunters & had 8% fuel blowpass. I use Silkolene 5/40 which has proved to be the best for my application, showing less than 2% fuel blowpass & maintaining its Spec after repeated runs.
10-04-2009 | 08:25 AM
always used mobil 1 15/50...........get it from matt lewis at a very good price
10-04-2009 | 08:26 AM
pete mcrash
Second that. Matt does it at a good price
10-04-2009 | 08:27 AM
MadRod
There is every need to change it at 3k, im probably the only one on here that has his oil chemically checked after a Topspeed run. Castrol RS was out of Spec after just one run down Brunters & had 8% fuel blowpass. I use Silkolene 5/40 which has proved to be the best for my application, showing less than 2% fuel blowpass & maintaining its Spec after repeated runs.
Fair enough for track use and top speed runs. I dunno if mike 1 does that or not. Should have asked.
For normal road use tho it shouldnt need changed that often surely?
MadRod
but most people dont go 200 mph.............has any tests been done on "normal" fast road cars.....??????
10-04-2009 | 08:35 AM
Why do people go for such thick oil like 15/50 - that must be very hard for the engine on coldstarts...I understand the 50 - but seems very thick oil when cold? I use Mobil 1 5/50 and change every 3K - works great
10-04-2009 | 08:54 AM
People writing on this subject say 'my engine likes or dislikes a certain oil' how do you know what your engine likes.
