GT30 fitting kits
GT30 fitting kits
Need help with the fitting kit for the GT Series turbo's -
I have spoken to AET about there kit which includes:
If someone can point me too parts needed that would be
- Banjo water fitting x2
- Banjo bolt x2
- Banjo washer x2
- oil return adapter
- oil feed restricter
reyland sell's a full kit for this turbo http://www.reyland.co.uk/Details.asp?ProductID=197
you need the restricor and an an-4 pipe, but only if thats what size the restrictor is!
like these http://cgi.ebay.co.uk/4AN-Oil-Restri...item19b879db6d
you will need pipe and an-4 line and fitting and the fitting for the oil pressue switch feed!
or use a banjo with a screw like this http://cgi.ebay.co.uk/Garrett-T25-T2...item1c0dde3ae1
standard turbos dont need a resistor there just as wide as the pipe, not sure on why it needs it on the gt turbos but without it they smoke like a fucker lol,
Almost there!
you will also need the adapter plate to go on the back of the turbo that converts the 4 stud GT30 to a 3 stud exhaust setup.
what exhaust manifold will you be using, as you may need the extra spacer within the 2wd manifold, and the associated longer bolts.
I think i have my head around it now - This looks like one way to go about it - fitting silicon hose to the banjo's and getting a local hydrolics company to supply the necessary lengths for the oil line. For the oil return just a piece of high pressure (if it needs) oil return pipe.
2 x Banjo kits
1m x 8mm 5/16" ID braided or Silicone Hose
1 x oil restrictor
2 x AN -4 (AN4) 90 degree oil fitting
2 x AN -4 (AN4) Straight oil fitting
1 x in line oil filter
1 x oil return pipe
2 x Banjo kits
1 x oil restrictor
1 x oil return pipe
09-10-2015 07:38 PM
