yank auto boxes
Old Jan 18, 2005 | 08:44 AM
darren.cudd's Avatar
darren.cudd
Default yank auto boxes
anyone know what yank auto boxes there are around that could be made to fit a yb lump?
granny cosworth box sounds like its going to be a right pain in the arse to get the electronic shifter to work
just want something thats strong as hell! and fairly simple technology
Old Jan 18, 2005 | 09:00 AM
darren.cudd
what time do the american boys wake up and get on this forum?
Old Jan 18, 2005 | 09:12 AM
B19-TRB's Avatar
B19-TRB
Might b worth a call to brom m8!
See if he knows what will bolt up!
what about a auto jag box!? or is it just the jag diffs brom uses!?
Old Jan 18, 2005 | 09:16 AM
darren.cudd
i have alreay pm'd him just waiting for a reply.
i think its just the jag diffs he uses.
would be nice if a jag auto would fit though..........but i very much doubt it that would be to easy
Old Jan 18, 2005 | 09:17 AM
darren.cudd
fook it! at this rate im just going to fit a manual and say i'll go out with him when he wants and change gear for him
Old Jan 18, 2005 | 09:18 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Mastangs use T5s likes cossies.
Mustangs also use drag autoboxes (with cool stuff like transbrakes )
Mustangs with the above boxes are often turbod and push out well above 1000bhp.
Methinks you go to http://www.turbomustangs.com/forums/
American guy near me whos got some mad ford turbo V8 stuff said the bex he uses cost him around 400quid IIRC and is good for 1000bhp...
Old Jan 18, 2005 | 09:21 AM
darren.cudd
cheers steve thats a start
(stupid hat on) what are transbrakes?
Old Jan 18, 2005 | 09:29 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Transbrake, well have to ask DannyB how they work, but they hold the revs at whatever revs (usually pretty low, peak torque i think) and load up the engine/transmission so the car is on full boost at a standstill so you can leave the line on full boost and peak torque
And the noise of the turbo on the line is fookin incredible
Old Jan 18, 2005 | 09:47 AM
darren.cudd
ah right, so a bit like just holding a manual at 4k and then just letting the clutch out for a good start then?
Old Jan 18, 2005 | 09:58 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
No, if you hold a manual at 4k you wont be on full load and full boost, you wouldnt even be on full boost if you was bouncing off the limiter.
It makes the engine load as much as if the car was flat out in 5th up a hill, so its working its hardest, so the min you let off the transbrake and suddenly there no load it REALLY rockets off.
There no way of getting the car under the same load with a manual (itd stall) or an auto without a transbrake (its not the same as having 1 foot on brake n 1 on accelerator).
Later on il see if i can find some vids of turbo cars launching off the transbrake...
Youl need good tyres tho
Old Jan 18, 2005 | 10:02 AM
darren.cudd
ah right i got ya. so the break just aplies a little bit of friction to what would be the flywheel so that it loads up.
ive joined the mustang site and put up a post but i gues there all in bed at the moment
Old Jan 18, 2005 | 11:16 AM
extra14's Avatar
extra14
why not use the cossie autobox and replace the controls with simple? electronics.
I don`t know if it will be easy but i guess it will require the control of valves in a particular order.
What does everyone else think?
Darren
Old Jan 18, 2005 | 11:25 AM
darren.cudd
yes thats an option but after speaking to brenie about that box it sounds a little more tricky than that
the granny cosworth box uses a soloniod for the shift and torqe lock, now doing the gear shift could be done with buttons on the steering wheel (shift up, shift down) but what do i do about the torqe lock? just leave it so it never works or i would need to get a box of tricks made up to tell it when to engage dunno, going to pick one up this week that makic randy is very kindly donating i'll pull that one apart and have a play with the electrics and see if i can make it work i feel a head ache coming on already
Old Jan 18, 2005 | 11:29 AM
darren.cudd
just had a thought actually with regaurds to how to get the torqe lock to work when i want it.......recon if i took a shift light and tapped the feed to the change up light and sent that to the lock solonoid.......you see what i mean?
could just set the shift light at say 3000rpm so the lock would engage with the light
only problem is getting it to disengage when the box changes up which i guess it would need to do?
Old Jan 18, 2005 | 11:39 AM
extra14's Avatar
extra14
It is very easy to program a chip to do this, and use buttons on the stering wheel, or the rpm shift light would work!
Darren
Old Jan 18, 2005 | 11:42 AM
peteh's Avatar
peteh
Give Danny B a pm or ring him at Hauser Racing, they have shipments every month from the US, and his rear is a mustang one so he knows his stuff
Old Jan 18, 2005 | 12:11 PM
darren.cudd
thing is i know that the auto shift stick has to have a mechanical link to select 'park' so it can eject the locking pin but what about the other gears?
or will i still need a mechanical link for the lever but when its in drive i can just inform it when to change?
far as i know it just needs rpm and car speed so it knows when to change up or down, or kick down ect..... im going to have an electronic speedo on the dax so i wonder how hard it would be to use the granny ecu and just tap the wires were i need to so i can just shove the ecu under the scuttle and give it the inof it needs just to work the gearbox hmmmmmmmmm
Old Jan 19, 2005 | 02:17 AM
svony's Avatar
svony
darren.cudd... I was never much for the auto boxes but a few guys here in the states are running V8's and 2.3L turbo Pintos have been using the Ford C4 trans with a manual valve body.
PM me if you want me to get some more details
AJC
Oct 1, 2015 06:47 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
